Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
dancing temp gauge needle
Old Sep 6, 2007 | 04:53 PM
chock289's Avatar
Default dancing temp gauge needle
first off i'm a long time reader, first time posting,
you guys really know your stuff, i have learned alot about my honda from you guys so thanks in advance.
problem: 2004 civic dx 2dr 5sp, all stock, daily driver.
temperature gauge needle dances all over the place, sometimes it spins all the way around counterclockwise, sometimes pegged at H.
replaced: fan thermo switch, temp gauge sensor, new thermostat. disconnected battery for 15 mins,
needle went back to original postion, took for 10 ride, shut car off for 5 mins restarted car needle danced but stayed pegged below C. ???????
any help would be great...did a search but could not find anything. thanks,
Old Sep 6, 2007 | 05:35 PM
roost's Avatar
* B A N N E D *
looks like you just need a new thermostat
Old Sep 6, 2007 | 05:40 PM
chock289's Avatar
Default Re: (roost)
replaced with a new one, thanks though. i was thinking more along the lines of electrical.
Old Sep 6, 2007 | 05:45 PM
katzenjammer84's Avatar
If it is spinning wildly, I'd suggest checking your main grounds.
Old Sep 6, 2007 | 05:54 PM
chock289's Avatar
Default Re: (AcuraFanatic)
thanks, i'll check. would the ground just affect that gauge or all the gauges?? all other gauges work fine.
AudioFunk
Aug 13, 2016 03:27 PM
Dmascarenasp
Mar 14, 2016 11:15 AM
TshingY
Jan 25, 2010 12:59 PM
chock289
Sep 10, 2007 09:48 PM
chock289
Sep 9, 2007 05:55 PM
