Whats better a type r or a Gsr engine???
Old Sep 6, 2007 | 03:43 PM
fitted2k8's Avatar
Default Whats better a type r or a Gsr engine???
What is a better engine to make more power type r or a Gsr engine for a honda civic 96 ???
Old Sep 6, 2007 | 03:57 PM
jonathan13's Avatar
Default Re: Whats better a type r or a Gsr engine??? (fitted2k8)
type r starts out with more but gsr is a lot cheaper. id buy the gsr and spend the extra money on modding it. please search
Old Sep 6, 2007 | 04:03 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fitted2k8 &raquo;</TD></TR><TR><TD CLASS="quote">What is a better engine to make more power type r or a Gsr engine for a honda civic 96 ???</TD></TR></TABLE>
The Type R will make more HP stock, but it also costs a lot more, parts cost more, and they're a bit more rare.
What are your WHP goals?
Old Sep 6, 2007 | 04:08 PM
97Ej6mike's Avatar
Type R : cost's more, more HP stock
GSR: Costs a lil less, little less HP stock, but money saved can be used on parts for the motor.
Depends on what your budget is.
Read thru this
https://honda-tech.com/zerothread/878010
B18C1 (or JDM B18C)
These come out of an Integra GSR.
Pros
Good Hp and TQ numbers (170, 121 ft/lbs respectively)
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
Becoming moreso as people keep scooping them up
Slighty longer tranny than the ITR and B16
B18C5 (or JDM B18C)
This is found in the Integra Type-R. IMHO this is the best swap for a Civic.
Pros
GREAT HP and TQ numbers (195 and 134 ft/lbs)
High revving
Hand built motor from Honda
Optional factory LSD
Best transmission for a B series from the factory
Red valve cover
Cons
EXPENSIVE
If JDM ITR is used, the 36mm axle 32mm hub problems occur
Old Sep 7, 2007 | 08:08 AM
alanng0421's Avatar
the GSR will be enough ...couse my friend have one on his car...and he can beat the TSX ....SO fast man..and more cheaper than ITR engine
Old Sep 7, 2007 | 10:24 AM
fitted2k8's Avatar
Default Re: Whats better a type r or a Gsr engine??? (Syndacate)
Can you make about 400 whp with the gsr motor??
Old Sep 7, 2007 | 10:25 AM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fitted2k8 &raquo;</TD></TR><TR><TD CLASS="quote">Can you make about 400 whp with the gsr motor??</TD></TR></TABLE>
With a built bottom end and boost sure
Archidictus's Avatar
Unceasing Measure
Not on a stock block.
Go do some research before you ask nine million questions.
helpmeplease
Aug 31, 2005 04:25 PM
Maxboost00
22
Feb 2, 2005 02:00 PM
integraracer96
Aug 12, 2004 12:56 PM
FlipboiGSR
Mar 23, 2002 11:15 PM
BoM
Jul 19, 2001 03:31 PM
