LS/vtec; 12:1 compression; stock cams. Tuning question?
Old Sep 6, 2007 | 12:37 PM
pgpbubble's Avatar
Default LS/vtec; 12:1 compression; stock cams. Tuning question?
What timing maps are you guys basing yours off of? I used a base p30; p72; p73. All of them which the car still feels sluggish before vtec; I swapped in a friends ecu which is dyno tuned; Not sure what map its based off of; But it runs alot better. I think I see upwheres of 28-31* at WOT. Car is tuned on crome pro also.
Any tuners insite?
Old Sep 6, 2007 | 02:06 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: LS/vtec; 12:1 compression; stock cams. Tuning question? (pgpbubble)
stock cams on a 12:1 comp motor?
i hope your running high oct fuel because you are detaonating like no other...
get some cams in there and get it tuned.......
dont half *** it
Old Sep 6, 2007 | 04:00 PM
Chris Tune's Avatar
u should be running kinda close to from 20 - 25 degrees WOT... it SHOULD rock the last i had to tune ended up with like 22 WOT... not much that can be done on 93 octane with some compression
Old Sep 7, 2007 | 05:45 AM
pgpbubble's Avatar
Default Re: LS/vtec; 12:1 compression; stock cams. Tuning question? (Chris Tune)
well i copied my friends dyno tuned chip; put it in. and now I blew my diff. Anyone have a b16/ls diff? ASAP! help me out
Old Sep 7, 2007 | 06:11 AM
98vtec's Avatar
moderator emeritus
lucky you didnt blow up
Old Sep 7, 2007 | 06:22 AM
pgpbubble's Avatar
Default Re: LS/vtec; 12:1 compression; stock cams. Tuning question? (98vtec)
Motor has over 4k miles on it already; limiters at 7500; shift around 7200 when the CEL pops up. AFR's are anywhere from 14:1 to 12:1 throughout the whole tune as per the LC1 with crome pro.
edit: for the hell of it; dont mind the shitty intake/header.
EDIT IM STILL TRIAL USER AND CANT POST MORE THEN 5 POSTS; hahah. This is a ls block; usdm STD bore b16a2's, obd2 oil pump; stock b16 head; blox manifold; ITR throttle body. Other setup is a 01 gsr longblock; ITR cams; s2 manifold/s2 throttle body; Mugen 4-1 header.
Modified by pgpbubble at 7:59 AM 9/7/2007
Old Sep 7, 2007 | 06:33 AM
98vtec's Avatar
moderator emeritus
what timing does it run? whats the setup of the other engine?
Old Sep 10, 2007 | 07:36 AM
pgpbubble's Avatar
read above post
94 vtec
Jan 24, 2014 10:00 AM
xSteve_Ox
Engine Management and Tuning
Aug 21, 2010 12:28 PM
88cerx
Mar 27, 2006 06:55 AM
infamousALLMTR
Mar 13, 2002 10:24 AM
