how to install lower ball joints on 98 ex civic
Old Sep 6, 2007 | 12:36 PM
h22_crx's Avatar
Default how to install lower ball joints on 98 ex civic
Old Sep 6, 2007 | 12:54 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: how to install lower ball joints on 98 ex civic (h22_crx)
yes? are you asking? or telling?
Old Sep 6, 2007 | 02:15 PM
slowcivic2k's Avatar
Removing the knuckle makes it go a lot faster, so I suggest you do that. On the bottom of each ball joint, just under the boot is a snap ring that will need to be removed. Then you can use a big *** hammer on the stud to tap it out of the hole. For easier installation of the new ball joint, place it in the freezer until you are ready to install it. The will make tapping it in that much easier.
Old Sep 8, 2007 | 05:14 AM
aquajon74's Avatar
Default Re: how to install lower ball joints on 98 ex civic (slowcivic2k)
so the ball joint pops out threw the top of the housing? my lower ball joint boot is torn so i need to replace that one, i have it all disconnected and the hub out of the way it allmost looks like the ball joint needs to be pulled out not pushed out or maybe i am looking at things wrong.. thanks
Old Sep 8, 2007 | 05:03 PM
Default Re: how to install lower ball joints on 98 ex civic (aquajon74)
You ned to pop the ball joint out of the lower control arm first, and then do the steps above, it can be a bitch to get out, but since your replacing it, just use a pickle fork, which will make it go faster. Do not use a pickle fork if you plan on reusing the joint, as it tears the boot on the joint almost all the time.
Kevins89notch
21
Nov 4, 2013 06:17 AM
Pancho2193
Mar 11, 2011 05:10 PM
ryanevansoh
Apr 29, 2009 09:43 PM
halocore
Mar 7, 2009 04:34 PM
arielb1
Oct 31, 2008 12:29 PM
