Is this engine useable b18c welded in block guard
I decided to ask my fellow HTers if this is useable it currently bored 81mm should I bore it 81.5mm or should I scrap it.
http://www.we-todd-did-racing....cqmav
you can bore it out if 81.5 will clean up the cylinders but block guards should be installed below the deck for better cooling might get hot spots but you will not know that tell you run it
Dee
Dec 4, 2006 12:31 AM
