SPC performance camber kit
i use them.. they are alright. it hasnt come loose on my or anything even after a few spinouts. my only complaint is that it hits the strut tower???
I use them on my EF.
On a car running a roadrace ride height, the big adjustment nut on the top will bash into the top of the inner finder well under severe compression. I cut a hole in mine near the shock tower where the damage was. Now it has room to move, and I can adjust the camber from the top and without having to jack the car off the ground.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20Monster »</TD></TR><TR><TD CLASS="quote">i was thinking about that.. but i just didnt want to put any more holes in it</TD></TR></TABLE>
That part of the chassis is 2 or 3 layers of steel. I cut the holes & seem welded the edge of the hole to maintain rigidity. It's not exactly pretty, but it works bitchen.
I run them and i just beat the location by the strut tower where the ball joint hits up until i had enough clearance.
Other than that they work really well no play or damage after 2 years of hard abuse.
idc 91si
11
Nov 28, 2007 08:28 AM
