93 hatch b20 motor
Old Sep 6, 2007 | 09:20 AM
chris23pp's Avatar
Default 93 hatch b20 motor
i got a 93 hatch which had a 2000 gsr with obd1 ecu. hydrolocked the motor and now have stock b20 with gsr tranny. trying to find out what type ecu i can use on the b20 with the wiring harness from the gsr bcause i need to go thru inspection and get the vtech code off.. and also what type of cheap exhaust does anyone recomend i need to get this thing thru inspection asap
Old Sep 6, 2007 | 09:23 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: 93 hatch b20 motor (chris23pp)
How about the stock crv ecu?
Cheap exhaust = muffler shop.
Old Sep 6, 2007 | 10:13 AM
smileycvc's Avatar
Default Re: 93 hatch b20 motor (ek forever guy)
The crv is automatic it wont work. Get a chipped p28 and run a basemap or tune.
Old Sep 6, 2007 | 10:36 AM
vestalfootball72
Guest
Posts: n/a
Default Re: 93 hatch b20 motor (smileycvc)
ive got a b20 hatch and the ls ecu is hands down the best out there for a oem ecu. theres been a few articles on b20 chips, but the general idea is that unless its going to be dyno'd b20 chips dont really work all too well
Old Sep 6, 2007 | 11:46 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: 93 hatch b20 motor (vestalfootball72)
x2 chip the p28, but i would put the gsr head on that block first...
Old Sep 6, 2007 | 01:18 PM
vestalfootball72
Guest
Posts: n/a
Default Re: 93 hatch b20 motor (oneludesol)
id still run a p75 for a obd1 ls
Old Sep 9, 2007 | 06:51 AM
chris23pp's Avatar
if i put the head on there i dont know how reliable and id have to waste time gettin it sleeved and gettin the head worked on. i just need a reliable car for now till i get more money to rework everything..
Old Sep 9, 2007 | 08:15 AM
smileycvc's Avatar
If you are keeping the block stock and just swapping on a vtec head you dont have to sleeve the motor. Just check out this thread its for an LS/Vtec but with a B20 it the same idea. https://honda-tech.com/zerothread/1676914
kevinEJ
Nov 16, 2012 01:20 PM
6footmidget
Dec 23, 2009 03:20 PM
poland accord
Nov 7, 2007 02:47 PM
iloveb16
Mar 28, 2007 08:04 PM
