H22A Mid Shaft Bearing
Old Sep 6, 2007 | 03:11 AM
flatline911's Avatar
Default H22A Mid Shaft Bearing
H22A in 96 Accord.My mid shaft bearing has gone bad due to a bad axle shaking it to death and is causing a slight vibration at 20 and 40. What is the correct name for this bearing and where can I get one? Is this a dealer only part?
Thanks
Modified by flatline911 at 8:04 AM 9/6/2007
Old Sep 6, 2007 | 04:38 AM
bluedlude's Avatar
Default Re: H22A Mid Shaft Bearing (flatline911)
try searching half shaft or intermediate shaft to find the part you need. im not sure of the name of the bracket, but if you go to a honda parts site and search for those things you should come across it
*edit* i made it easier, its the "half-shaft bearing" #22 but you might need a couple more parts from there as well.
http://www.hondaautomotivepart...82%29
Old Sep 6, 2007 | 09:25 AM
Thanks alot!
acco
Jun 29, 2010 10:14 AM
Agent Daimon
Apr 3, 2008 05:04 PM
Y2ksi
Oct 29, 2005 08:37 AM
12345
Jun 24, 2005 07:04 AM
