camber question
Old Sep 5, 2007 | 10:09 PM
shibbywhitedude's Avatar
Default camber question
I'm about to lower my car with the Eibach Pro Kit. I know that the camber will be a little bit off after that and I'm a perfectionist. Does anyone have any idea as to how close it will be off? And can it be adjusted back to completely normal on the 98-02 Accords like at an alignment shop? Thanks in advance.
Old Sep 5, 2007 | 11:05 PM
pos_cd5's Avatar
Default Re: camber question (shibbywhitedude)
the front will be only off by a tiny bit since macpherson struts have very little camber gain during compression. the rear however will be a little more noticeable. it can be changed back to stock specs with the use of a camber kit, but depending on your drop it might not be necesary and can even benefit you if you do some hard driving. what usually kills tires when lowering is not camber but toe, so you should be more worried about that when setting your alignment after the drop.
Old Sep 6, 2007 | 04:53 AM
stinker504's Avatar
There is no factory adjustment for the 6th gen camber. Ingalls sells a camber kit for the front and rear if you're super picky.
Old Sep 6, 2007 | 11:16 AM
lol. I'm VERY picky. That camber kit will allow me to get it back perfect? hopefully lol
Old Sep 6, 2007 | 11:20 AM
Oh and I should add that the Pro Kit only lowers your car 1.5 inches. Is that big enough of a change to make a huge difference in tire wear? I wish I could find some Accords my year model with the Pro Kit installed.
Old Sep 6, 2007 | 03:04 PM
pos_cd5's Avatar
Default Re: (shibbywhitedude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shibbywhitedude &raquo;</TD></TR><TR><TD CLASS="quote">lol. I'm VERY picky. That camber kit will allow me to get it back perfect? hopefully lol</TD></TR></TABLE>
even better, with the kit and a good tech to do the alignment, you can be better than 'perfect' since no car really comes with 'perfect' alignment left to right from the factory.
Accord-Guy
Suspension & Brakes
May 12, 2010 03:29 AM
Accord-Guy
May 7, 2010 06:12 PM
Dirty Octopus
28
Feb 20, 2010 05:47 AM
nindoo
Honda Civic (2006 - 2015)
Jul 30, 2007 08:23 AM
jonoknut
Sep 15, 2002 08:10 PM
