code 43.14 EG/B16a2 HELP
Old Sep 5, 2007 | 09:45 PM
-HONDA-'s Avatar
Default code 43.14 EG/B16a2 HELP
okay here is the deal with my car/motor!, i just swapped in a b16 that i test drove etc... and then put it in my eg and now my idle is jumping from 1k to 1.5K constantly. no engine light at first but tonight i was just driving it normally and my engine light finally turns on thank god so i can figuere out my problem. first of all i cleaned out my IACV screen and idle was still the same, Second i changed the IACV with another one and it was still idleing weird. now im throwing codes 43,14
43= is fuel system something???
14= is IACV
so what should i do? LMK if you guys have had this problem thanks.
Old Sep 6, 2007 | 02:22 AM
crazyguy's Avatar
Default Re: code 43.14 EG/B16a2 HELP (-HONDA-)
i think i might have the same problem.
but does your CEL go away next time u start the car?and then it will come back on when the engine is at normal working temp?
Old Sep 6, 2007 | 11:41 PM
-HONDA-'s Avatar
yes
Old Sep 7, 2007 | 07:52 AM
crazyguy's Avatar
Default Re: (-HONDA-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -HONDA- &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
i found out why my CEL is on.all i need is a chipped ecu with knock sensor disable.bump for this guy.anyone knows how to deal with the problems?
thanks
wazman
May 6, 2009 10:13 AM
freshvibes
Feb 27, 2009 09:45 PM
NJcivic21
Nov 9, 2005 11:44 AM
Bruce_Willis
Dec 10, 2004 10:37 AM
