Altenator
Old Sep 5, 2007 | 08:22 PM
koa's Avatar
koa
Default Altenator
Could a bad alt make my car have no fuel pump or starter???
Old Sep 5, 2007 | 08:25 PM
forcefedferio's Avatar
Default Re: Altenator (koa)
no, a dead battery would....alternator could be the cause of a dead battery though. so through the 3 degrees of automotive electricity i guess you could say it could cause it.
Old Sep 5, 2007 | 09:17 PM
koa's Avatar
koa
Default Re: Altenator (forcefedferio)
my battery is reading 13 votls good connections...so in other words it it could cuz tht
Old Sep 5, 2007 | 09:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa &raquo;</TD></TR><TR><TD CLASS="quote">my battery is reading 13 votls good connections...so in other words it it could cuz tht
i think there were two seizures that just took place, one while you were typing that and one while i was reading that.
Does the car start? chances are a bad alternator is not causing a fuel pump failure or a starter failure, if your batter is reading 13 volts while the car is running you are ok, it's a little low for charging voltage but not really condemnable...if it is reading 13 volts with the car off you are overcharging the battery in which case your alternator is no longer functioning properly.
Old Sep 5, 2007 | 09:30 PM
koa's Avatar
koa
battery is good. connections tight.no cranking over no fuel pump or relay.
Old Sep 5, 2007 | 09:35 PM
koa's Avatar
koa
if it is not functioning properly will that cause my fuel pump and starter properly?
Old Sep 6, 2007 | 12:02 AM
xerokill's Avatar
sounds more like a fuse problem, that is if the starter and fuel pump went out at the same time, it's not very likely that two components would fail together like that
Seanmo
Honda Ruckus and Scooters
Mar 14, 2018 06:35 PM
JUN.
Jan 25, 2010 07:55 AM
Integ808
Oct 16, 2008 02:57 AM
thehatchninja
Apr 1, 2004 03:10 PM
JDMvtecDRAGSTA
13
Mar 7, 2004 10:38 PM
