My Car Smokes White :S Some 1 help
hey guys i gott a B16a in ef9 civic i recently did Dc 4-2-1 header and a Mugen Full Exhuast system , and also a B&M fuel presure regulator , ever since i changed these parts my car smokes white sometimes , doesn burn any oil and did a compresion check , could it be that the OEM header has 2 O2 sensors and the Dc 4-2-1 only has 1 hooked up ? the car is runing way 2 rich , and whenever i do a pull my ENGINE light will come on , could it be that only 1 o2 sensor is hooked up ?? some 1 plz help
What obd system are you running obd0 still?
What code is it?
Does it smell semi sweet? What's your coolant level look like?
What code is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">I'd be willing to bet it's due to the completely unnecessary adjustable FPR that was installed. What PSI does it read?
What code do you pull when the CEL comes on?</TD></TR></TABLE>
x2
x2
civiccph22
Mar 3, 2004 01:52 PM
