b series swap shift linkage question
Old Sep 5, 2007 | 03:49 PM
Banjo the Ninja's Avatar
Default b series swap shift linkage question
Will any b series shift linkage work? I am swapping a b18b1 into my '93 si, and was wondering if I got a shifter from a 93 integra if it would still work, should be the same lenth and everything, and I don't see a reason why it wouldn't, but figured I'd throw it out here for some feedback.
Old Sep 5, 2007 | 03:50 PM
95ProjectEJ1's Avatar
Default Re: b series swap shift linkage question (Banjo the Ninja)
bump for answer because im curious too
Old Sep 5, 2007 | 03:52 PM
crazyguy's Avatar
i know for sure 94 up integra will fit.but i have heard da integra will fit too.and i know for sure del sol vtet (b16a2) wont fit cause it is too short
Old Sep 5, 2007 | 04:31 PM
Default Re: b series swap shift linkage question (crazyguy)
Yea I know del sol/crx shifters won't work cuz of the size of the cars, but from a DA Integra it should be the same length. Anybody tried it?
Modified by Banjo the Ninja at 7:13 PM 9/5/2007
Old Sep 5, 2007 | 04:40 PM
gsxr1k05's Avatar
i was told that the stock integra linkage will fit for my 95 civic. guess someone has to try it and let us know.
Old Sep 5, 2007 | 06:45 PM
pat92si's Avatar
Default Re: b series swap shift linkage question (gsxr1k05)
bump because ive never heard anything about this.
Old Sep 5, 2007 | 06:48 PM
devney's Avatar
pretty sure any b series linkage will work if I remember right...except del sol (and crx?)
Old Sep 5, 2007 | 06:50 PM
Murk 'EM's Avatar
Default Re: (devney)
94-01 gsr integra shift linkage..only
Old Sep 5, 2007 | 06:51 PM
forcefedferio's Avatar
Default Re: b series swap shift linkage question (pat92si)
any b-series linkage EXCEPT the obvious CR-V linkage (when equipped with a M/T) and a Del Sol VTEC shift linkage will not work either as they are different. i'm not sure about the DA integra linkage though.
Old Sep 5, 2007 | 07:19 PM
Murk 'EM's Avatar
Default Re: b series swap shift linkage question (forcefedferio)
i was told my whipfactory that if your puttin a B in a 92-95 civic you get eveything for a 94-01 integra ONLY... cause thats what im doing and im not saying your wrong.. but there more right
Old Sep 5, 2007 | 07:25 PM
Default Re: b series swap shift linkage question (95_acc0rd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_acc0rd &raquo;</TD></TR><TR><TD CLASS="quote">i was told my whipfactory that if your puttin a B in a 92-95 civic you get eveything for a 94-01 integra ONLY... cause thats what im doing and im not saying your wrong.. but there more right</TD></TR></TABLE>
Why are they "more right"? They are right, however half right is still right i guess.
It's just easier to think when putting a b-series in a 5th gen civic you will always be in better shape sticking with parts from it's b-series counterpart the 94-01 integra. Certain things like A/C brackets and what not will be interchangeable regardless but save yourself the hassle and buy factory integra stuff. If you think about it stripped engine bays i'll bet you 9 times out of 10 you won't be able to tell the difference between a 94-01 integra and 92-95 civic.
Old Sep 5, 2007 | 07:28 PM
Murk 'EM's Avatar
you wont there exactualy the same and i was saying more right cause i trust what they do
Old Sep 5, 2007 | 07:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_acc0rd &raquo;</TD></TR><TR><TD CLASS="quote">you wont there exactualy the same and i was saying more right cause i trust what they do</TD></TR></TABLE>
you mean you don't trust everyone on honda-tech?! haha
this book will tell you everything you need to know, i recommend it to everyone it's only $19 and the information in it is so helpful.
Old Sep 5, 2007 | 07:55 PM
95civiccpdx's Avatar
it wont wok 94 up integra or b series civi only
Old Sep 5, 2007 | 08:01 PM
Murk 'EM's Avatar
Default Re: (95civiccpdx)
true that the book will be a huge life saver
Old Sep 6, 2007 | 01:07 AM
BlueIntegraBoy's Avatar
To correct some people, 90-93 Integra shift linkages will work.
https://honda-tech.com/zerothread?id=1853425
Old Sep 6, 2007 | 06:13 AM
Default Re: b series swap shift linkage question (BlueIntegraBoy)
Awesome man thanks for the link, when I searched I searched for "integra linkage" so it didn't come up, appreciate it a ton.
Old Sep 6, 2007 | 02:06 PM
pat92si's Avatar
Default Re: (95_acc0rd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_acc0rd &raquo;</TD></TR><TR><TD CLASS="quote">94-01 gsr integra shift linkage..only</TD></TR></TABLE>
how bout LS/RS their all the same.
Old Sep 6, 2007 | 02:52 PM
92_civicsi's Avatar
Default Re: (pat92si)
ya, they should all be the same
Old Sep 9, 2007 | 08:51 AM
Default Re: (92_civicsi)
Well I am buying a DA linkage, so I will post here for further confirmation/disproving of whether or not it will work.
gsrpedro
Aug 20, 2008 11:23 PM
qwert12
Jun 8, 2007 05:14 AM
nicko360
May 9, 2007 04:36 PM
DelSiRII
Sep 10, 2004 10:47 PM
P1mpSlap
Apr 28, 2003 06:56 PM
