How do I baffle my catch can?
Old Sep 5, 2007 | 01:30 PM
vtec_lude's Avatar
Default How do I baffle my catch can?
Hi guys,
I'm a bit unsure of how to baffle my catch can. I don't want to use steel wool. Would I be able to use a perforated bit of steel inside the catch can just to break up the air flow?
Thanks
Old Sep 5, 2007 | 09:45 PM
Top Ramen's Avatar
Default Re: How do I baffle my catch can? (vtec_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_lude &raquo;</TD></TR><TR><TD CLASS="quote">
Ask it how David Spade keeps getting work. . .
Old Sep 6, 2007 | 05:53 AM
C1V1C's Avatar
some people just use steel wool
Old Sep 6, 2007 | 07:51 AM
Mr.E.G.'s Avatar
Default Re: How do I baffle my catch can? (Top Ramen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top Ramen &raquo;</TD></TR><TR><TD CLASS="quote">
; )</TD></TR></TABLE>
hahahahahaha. baaazing!
Old Sep 6, 2007 | 08:22 AM
kommon_sense's Avatar
Default Re: How do I baffle my catch can? (C1V1C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C1V1C &raquo;</TD></TR><TR><TD CLASS="quote">some people just use steel wool</TD></TR></TABLE>
You want to be careful with steel wool. It can break down and break off. This is a problem for people who set their can up to recirculate to the oil pan. Another option is to buy a few feet of chain from the local hardware store and put it in the can.
Old Sep 6, 2007 | 08:43 AM
Niles's Avatar
If you do end up using steel wool, it should be stainless.
Old Sep 6, 2007 | 09:08 AM
G2turbo_terror's Avatar
Default Re: How do I baffle my catch can? (Niles)
What do aftermarket catch cans like the greddy have inside? Perferated steel w/small holes?
Old Sep 6, 2007 | 03:41 PM
mike93eh2's Avatar
Default Re: How do I baffle my catch can? (G2turbo_terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2turbo_terror &raquo;</TD></TR><TR><TD CLASS="quote">What do aftermarket catch cans like the greddy have inside? Perferated steel w/small holes?</TD></TR></TABLE>
nothing..
i use scotch brite pads.
Old Sep 7, 2007 | 05:59 PM
dart2.2's Avatar
Default Re: How do I baffle my catch can? (mike93eh2)
summit racing sells weld in baffles. part# mor68800.
Old Sep 8, 2007 | 06:42 AM
MK's Avatar
MK
Default Re: How do I baffle my catch can? (dart2.2)
Use Perf you can buy 12" X 12" sheets from a few diff. suppliers for a few bucks. PM and I will give you a website that has it.
Old Sep 8, 2007 | 08:37 AM
RCautoworks's Avatar
Default Re: How do I baffle my catch can? (MK)
Just use metal, you don't need steel wool
Old Sep 8, 2007 | 12:58 PM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dart2.2 &raquo;</TD></TR><TR><TD CLASS="quote">summit racing sells weld in baffles. part# mor68800.</TD></TR></TABLE>
that looks tobe a breather filter with a shield on it.
Chris
Old Sep 8, 2007 | 03:49 PM
-RedneckDave-'s Avatar
Working
Default Re: How do I baffle my catch can? (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
Chris</TD></TR></TABLE>
If you look inside the tube of that part then you will see that it is not just a straight through piece of tubing. It has a metal baffle in the middle. It is not the best but it does work.
Old Sep 9, 2007 | 07:27 PM
nonsense's Avatar
Default Re: How do I baffle my catch can? (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense &raquo;</TD></TR><TR><TD CLASS="quote"> Another option is to buy a few feet of chain from the local hardware store and put it in the can.</TD></TR></TABLE>
I've read that ball chain works well for a baffle
Old Sep 9, 2007 | 09:37 PM
greasemonkee's Avatar
Default Re: How do I baffle my catch can? (nonsense)
These look like a pretty good deal, I might even buy a case to repack dead resonators.
http://www.reliablepaper.com/L...r.htm
Old Sep 10, 2007 | 04:24 PM
93LSivic's Avatar
Default Re: How do I baffle my catch can? (greasemonkee)
The moroso breather setup above is what I make our catch cans with. There is actually 2 baffles in each one of the weld in tubes. If you have a return style catch can I wouldn't ever consider putting anything in the box....doesn't take much for the oil pickup screen to get clogged and cause an engine failure if the "baffle" comes apart.
Old Sep 13, 2007 | 10:28 PM
90DALS's Avatar
gutter gaurd. it comes in a roll.
cut it down to about a foot. roll it up and drop it in. its same thing as metal grating (perf), just cheaper.
saywhat
Jun 12, 2006 04:11 PM
@irborne
Welding / Fabrication
17
Nov 6, 2005 04:32 PM
sebZZ
Jun 4, 2005 09:18 PM
jDMJeRk
Jul 28, 2004 09:33 PM
GreenBean
Apr 13, 2003 01:43 PM
