How to fix this rust near top of windshield and moonroof? 95 Civic 4dr
Old Sep 5, 2007 | 10:59 AM
johnson_n's Avatar
Default How to fix this rust near top of windshield and moonroof? 95 Civic 4dr
I know someone who can do body filler but doesnt know how to weld. Two rear arches will cost around $100 on http://www.rustrepair.com + cost of having someone weld in the panels. Does it look bad enough that I should get new panels put in?
And how much would some of you guys on here charge to clean this up where the sunroof is?
Old Sep 5, 2007 | 12:08 PM
RIZOBIZERT's Avatar
Default Re: How to fix this rust near top of windshield and moonroof? 95 Civic 4dr (johnson816)
You've got cancer. The best way to deal with cancer is to cut it out, but if you can save panels it's not cheap. I manage a shop in Florida and you're looking at a minimum of $600 for the roof (you should pull the windshield) and $400 for the quarter. The fender is easy enough, it just bolts on, bolts off, so if you can't fix it, just get a new one, but you should be able to fix it based on what I see. This repair is quoted at $40/hr. with $22 for paint and material. This would be the minimum cost to have a reputable shop do it.
Old Sep 5, 2007 | 01:02 PM
johnson_n's Avatar
Default Re: How to fix this rust near top of windshield and moonroof? 95 Civic 4dr (RIZOBIZERT)
What would be done to the roof? All new metal?
The first two pictures are of the rear quarter panels.
Old Sep 7, 2007 | 05:32 AM
WhiteOnRice's Avatar
You don't need the rust repair panels. Just cut and patch.
This is how far I had to cut to get clean metal.
Old Sep 8, 2007 | 03:14 PM
phatboycrxhf's Avatar
Default Re: (WhiteOnRice)
i have the same deal on my teggy
here is the rust ive been dealing with lol
i have the same kinda rust near my windsheild ,but i don't think its as bad ! But id sand blast and see what it looks like after that ,if there is stell metal there and its not a huge hole then there isnt any need to cut and patch !!!
good luck and don't be scared ! its only rust !
Old Sep 8, 2007 | 05:20 PM
sc4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice &raquo;</TD></TR><TR><TD CLASS="quote">You don't need the rust repair panels. Just cut and patch.
It's more involved fixing it this way, and much harder to get an oem look when you splice through the center of a panel like that. Are you trimming sheetmetal from scratch to rebuild the quarter? I would have definitaley bought a quarter panel and replaced as a whole unit......just for the time saved, not to mention all the areas where rust will grow.
Old Sep 8, 2007 | 11:26 PM
MEAN88Si4WS's Avatar
Default Re: (sc4dr)
I would just grind the rust down and bondo it. Ive done that many times and fixed many rust holes. Bondo cost 10 bucks, a lot cheaper than $1000 to do it the welding way....
Old Sep 10, 2007 | 04:28 PM
atleast-3's Avatar
Default Re: (MEAN88Si4WS)
yea thats ok if you only plan on having the car for a short period of time because that rust will eventually come right back through the bondo. then you have a real mess, cracked paint and bondo AND rust. guess it all depends on what you plan on doing with the car...... if its just goin to be a daily beater than maybe you dont care about bondoing it up. but if its going to be more than that id definitly cut and replace the metal with patch panels.
Old Sep 10, 2007 | 05:34 PM
kiddcarbuff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MEAN88Si4WS &raquo;</TD></TR><TR><TD CLASS="quote">I would just grind the rust down and bondo it. Ive done that many times and fixed many rust holes. Bondo cost 10 bucks, a lot cheaper than $1000 to do it the welding way....</TD></TR></TABLE>hack much? thats butcher ****
Old Sep 11, 2007 | 03:18 AM
sc4dr's Avatar
Default Re: (kiddcarbuff)
^ ^ As long as hes not getting paid to do this, he can do whatever he wants. It's when a body shop does work like this you have to wory about.
Riken
Sep 12, 2009 05:55 PM
fambern
Jan 18, 2009 04:30 PM
mgcivic359
Nov 3, 2006 08:00 PM
kikoman0
Jan 5, 2005 03:26 PM
