Quick qustion for intake manifold spacer gasket
Old Sep 5, 2007 | 10:49 AM
sohczcturbo's Avatar
Default Quick qustion for intake manifold spacer gasket
Alright, it time to start putting my zc motor back together now that all the machine works been done. I was starting with the head and swapped the d15b7 intake manifold for sake of vacuum lines not having to be reran. But I noticed something. It looks like the intake manifold spacer (pholenic spacer or how ever you spell it) is blocking a coolant passage from the head to the intake manifold to the coolant tube on the back of the block. I might be wrong, but I'm double checking. Should I make a hole in the spacer where this "coolant hole" is, if it's even that? Here's some pics
There's the hole...
There it's not...
Old Sep 5, 2007 | 11:03 AM
Default Re: Quick qustion for intake manifold spacer gasket (sohczcturbo)
bump in honor of viva la build
Old Sep 5, 2007 | 11:46 AM
bump
smg0248
Jan 15, 2019 08:02 PM
92G
May 25, 2018 08:40 PM
NZDelsoldude
Feb 16, 2006 01:18 PM
Kapolei INTEGRA
Aug 13, 2005 09:05 AM
