Very Poor blower performance?
Old Sep 5, 2007 | 09:45 AM
VTEC-LUDE's Avatar
Default Very Poor blower performance?
Hello,
wonder if anyone can help. My 1997 civic ek4 vti (uk model b16a2 engine) has very, very poor blower performance. THen fan seems to be operating with full power as it can be heard ''whoosing'' in the footwell.
However, only a very minimal amount of air seems to be reaching the vents, no matter what option is selected?
Any ideas what this could be- i was thinkin maybe a blocked pollen filter or something? At the moment i have removed all the dash, metal bar etc but cant find the pollen filter..
Old Sep 5, 2007 | 10:02 AM
ekb16's Avatar
have u tried taking out the blower motor and cleaning it out..could be abunch of leaves n **** in there
Old Sep 5, 2007 | 10:09 AM
VTEC-LUDE's Avatar
Default Re: (ekb16)
I'll give that a bash now mate.. anywhere else i should look for leaves etc? I presume that the blower motor is that black thing on the bottom held on by a few screws?
I'll go and remove it now
Old Sep 5, 2007 | 10:24 AM
VTEC-LUDE's Avatar
Default Re: (VTEC-LUDE)
Blower motor now removed. Blower motor had a small number of leaves in it- nothing i would think that could be soley attributable to the loss in blower performance expereinced.
Is there anythin else i should do or check/clean before putting every back together and testing it?
Old Sep 5, 2007 | 10:37 AM
Vindicator9000's Avatar
318 Curves, 11 miles
I would try plugging in the blower while it's out, and making sure that it's running full speed. If so, then you have a clog, most likely in the vents inside the car.
If it's only doing it while you have it on fresh air, then you could have a clog under the cowl cover.
Agent_EM1's Avatar
radiator?
Old Sep 5, 2007 | 10:49 AM
VTEC-LUDE's Avatar
Default Re: (Agent_EM1)
Where about should i look mate?
Update; Everything is put back together now, this has increased blower performance slightly. A little more air is now coming through- but it is still only about 10% of what it should be.
Is there anywhere else leaves or other debris could have accumulated?
Old Sep 5, 2007 | 11:01 AM
awdgsx96's Avatar
What about the cabin filter being clogged?
Old Sep 5, 2007 | 11:13 AM
VTEC-LUDE's Avatar
Default Re: (awdgsx96)
How do i check that mate?
Old Sep 5, 2007 | 05:56 PM
awdgsx96's Avatar
I'm not too sure about it for the Civic, but I'm pretty sure you'll have to remove the glovebox and maybe part of the dash to access it.
Old Sep 5, 2007 | 06:39 PM
forcefedferio's Avatar
i don't think 6g's have cabin air filters...i could be wrong for the uk i dunno...could be a bad switch, can you hear the blower spinning faster when you crank the speed up?
Old Sep 5, 2007 | 06:47 PM
Murk 'EM's Avatar
Default Re: Very Poor blower performance? (VTEC-LUDE)
its the filter... have fun changing it..
Old Sep 5, 2007 | 09:07 PM
lsturboguy's Avatar
Default Re: Very Poor blower performance? (95_acc0rd)
the filter on my heater core was clogged.. maybe it was just the heater core itself. but on cold it would blow hard.. on hot it wouldnt blow very well.. took the cover off nd blew it out.. problem 50 percent better... so i left it haha
Travis
Old Sep 5, 2007 | 09:16 PM
gtlaw1's Avatar
blower resistor
Old Sep 6, 2007 | 08:35 AM
VTEC-LUDE's Avatar
Default Re: (forcefedferio)
All the settings work fine mate. Ie.. the fan speed can be increased but no additional air flow occurs, but the fan is defiantely increasing.. the air is just not coming out.
I have got a diagram of where the pollen filter is now and i'm going to go remove it- i hope this is the filter everyone is suggestion i change. I don't currently have a replacement- is it ok just to remove it and see if it works better? I'll be able to get a new one form honda tomorrow.
Cheers for the help lads
Old Sep 6, 2007 | 11:05 AM
VTEC-LUDE's Avatar
Problem now fixed- fan works 100%! After removing the pollen filter a small forest was locatated in the pollen filter housing and hoovered up
holmesnmanny
Honda Civic (2006 - 2015)
Feb 18, 2016 01:42 AM
PowerLeg
Mar 24, 2012 12:24 AM
acuratl
Acura TL, RL & ZDX
Nov 5, 2007 04:13 PM
kannon
Oct 9, 2002 04:05 PM
