FS: CHEETAH's garage sale NJ - b-series and k-series stuff plus more...
time to clear out a few things, will post pics as I take them. open to trades but would prefer to sell outright, unreasonable offers will be refused.
1) TWM 52mm ITBs B16/ITR - used for couple dyno passes, new style - $1250
2) TWM 50mm used quite a bit a even went thru an engine fire but works fine - $800
1) and 2) can come with ITG filter kit for extra $150
3) LS 86mm block with 3/4" deckplate and headstuds, adj water pump pulley, perfect deck for 92mm crank with 5.938 rods (also available) - $800 neg /$950 w/ rods
4) AEM EMS 1000 (92-95 Civic/ OBD1 Integ/Accord/Prelude) used - $750
5) Z10 Motorsports oil sump kit for b-series with 99% lines needed incl external oil filter and adapter - $1500 w/ oilpan
6) Toda spec C camshafts for B-series used in good condition (2 sets - one for a friend as well) - $650 per set
7) Custom ITBs for B16/ITR head pattern made from 4AGE Toyota ITBs and uses stock b-series fuel rails and injectors - $400
8) 05/06 Type S 6spd K-series tranny (in parts but can assemble so I can put an LSD in it if you supply LSD) - SOLD
9) B20/VTEC longblock with 12.5:1 compression pistons and eagle rods and B16 head with JG/Victor X manifold - stock B16 cams/head $1500
10) CTR longblock no cams and manifold - sold
11) Skunk2 stg 2 K20A camshafts used - $450
12) bare PRB K20A2 type s head, needs valves/valveseals, etc. - SOLD
13) K20A2 Type S shortblock (x3) - $800 each with pistons, crank and oilpan; $500 bare block with crank (1 left)
14) 90 CRX HF, very nice condition except for drivers fender - with nice builtup B-series, ran 12.5 @ 109 mph weighing 2310 lbs on street tires $offers
15) 89 Civic EF Si built b20/vtec, LSD, etc. with over 200K miles and exhaust leak, paint faded -$3500neg
16) Sleeved K20A2 shortblock with JE 9:1 turbo pistons and Eagle rods, newly assembled $2500
17) K24A4 Accord longblocks (x2) needs flywheel/clutch/tranny to be complete swap - $1200 each
pm or email GBRTuning@aol.com
greg
pics:
Modified by CHEETAH at 4:30 AM 9/13/2007
Modified by CHEETAH at 3:16 AM 11/4/2007
Modified by CHEETAH at 3:17 AM 11/4/2007
Modified by CHEETAH at 1:19 AM 12/3/2007
greg
pics:
bump for bad *** deal on the ctr longblock. wish i had the extra $. is it a ctr head also/w full valve train. is the block in good running condition
thanks bump ...
got seats in the CRX chassis ... now a nice complete looking street car with a nice motor, cahssis still for sale after Etown Fall Nat'ls preferably.
