K Sport big brake kit
Old Sep 5, 2007 | 05:01 AM
reptar_head's Avatar
Default K Sport big brake kit
So I searched and couldn't find anyone that has used the K Sport big brake kits for the 4th gen Prelude. I know most people say you don't really need bigger brakes and just get some good rotors and pads and call it a day, but that's just not me. I want front and rear brake kits with new calipers, and K Sport seems to be the only one to offer a rear kit. So, has anyone used these?
Here's a link to them - http://www.ultrarev.com/home.php?cat=324&page=2
Old Sep 5, 2007 | 05:20 AM
95PreludeSi's Avatar
Default Re: K Sport big brake kit (reptar_head)
What will your plan be with this brake setup? Do you plan to track the car?
You should look into the avalibility of replacement rotors as well. They might be really expensive, and if you track the car you will go through rotors.
Just something to think about.
Right now I can get brembo blanks for about 25ea and use them for a few events and get new ones. It would take a long time to re-coup that cost with one of those kits, if they would even last longer.
Old Sep 5, 2007 | 06:00 AM
117's Avatar
117
I didn't realize that brake kits could be rebound and compression adjustable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The Ksport big brake kit includes:
8-Piston Aluminum calipers
High quality brake pads
Compression/Rebound adjustable
D.O.T. Compliant Stainless steel brake lines
Machined aluminum hats
Carbon steel brackets
13 or 14 inch large ventilated discs
Ksport SC5 street brake pads (RC1 race pads available for additional cost)</TD></TR></TABLE>
13" rotors will call for a 17" wheel at a minimum, IIRC, so that's another thing to consider. I like using 15s on my track car, so I'm planning to run a Fastbrakes kit. He doesn't offer an OTS rear kit, but he can put one together for you. I was planning to do that, but the kit won't save much weight over the stock setup, so it's just easier to use the stock rear calipers and rotors.
As pointed out above, the major considerations, are availability and cost of replacement rotors and pads. If the pads and rotors are not widely available, this could be an issue. That's another reason why I like the Fastbrakes kit and the Spoon kit. Fastbrakes uses Wilwood calipers and rotors (11.75" OD) which are easy to find (and less expensive than OEM!) and Spoon uses the stock pads and rotors.
I know Chris F uses the Fastbrakes kit on his 4Gen HondaChallenge H1 car with very good results. I'm hoping to have equally good results with the 6 piston kit on my 5Gen. I'm doing the mock up tonight to make sure everything fits right.
Old Sep 5, 2007 | 03:42 PM
Default Re: K Sport big brake kit (95PreludeSi)
The car won't be autocrossed at all. It might see the drag strip once or twice. Other than that, it's just a daily driver/show car. The car already has 17"s, so as long as the backspace is ok then there's no problems there. I don't see the brakes getting abused, so I think the rotors would probably last quite a while, and the pads shouldn't be a huge problem to find when the time comes to replace them. I'm just wondering if there's a reason I've never seen a prelude with this kit (other than the price tag).
Old Sep 5, 2007 | 03:47 PM
94Vtecluder's Avatar
A whole bunch of people make big break kits, question is how much are you looking to spend?
http://www.modacar.com/product...DABBK/
Old Sep 5, 2007 | 04:17 PM
Default Re: K Sport big brake kit (94Vtecluder)
I know there are a lot of kits, but k sport is the only one I've found that offers a rear kit with a replacement caliper to match the fronts, that's why I'm drawn to it. But, I've yet to see a prelude with this kit on it so I'd like to see if anyone has any experience with them and can give some feedback.
Old Sep 6, 2007 | 07:27 AM
alterdcreations's Avatar
looks good for all show
go with 14" in the front and 13" in the back.... ballar
Old Sep 6, 2007 | 09:49 AM
bb_one's Avatar
Default Re: K Sport big brake kit (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">looks good for all show
go with 14" in the front and 13" in the back.... ballar</TD></TR></TABLE>
Better yet, dual calipers in the back.... FTW
Old Sep 6, 2007 | 04:20 PM
Default Re: K Sport big brake kit (bb_one)
I'll admit a good part of my interest in the kit is the show of having both front and rear matching calipers. I hate seeing a big bad *** front brake kit and a stock caliper in the rear. Also, the front have the most pistons of any big brake kits I've seen. Of course, that doesn't necessarily mean they'll brake any better than any other kit, but it definitely helps in the decision to try and get the best the first time.
Old Sep 10, 2007 | 03:32 PM
for no one having this kit. Maybe I'll be the guine pig and just get them, then I'll do a write up and such.
Old Sep 10, 2007 | 03:51 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reptar_head &raquo;</TD></TR><TR><TD CLASS="quote"> for no one having this kit. Maybe I'll be the guine pig and just get them, then I'll do a write up and such.</TD></TR></TABLE>
Old Sep 10, 2007 | 07:49 PM
kadidle's Avatar
Default Re: K Sport big brake kit (DfwBB6)
did you notice you cant use your ebrake handle theres no cable hook up you might as well get a front kit and put your front calipers in the rear with some custom brackets
Old Sep 10, 2007 | 08:10 PM
117's Avatar
117
Default Re: K Sport big brake kit (kadidle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kadidle &raquo;</TD></TR><TR><TD CLASS="quote">did you notice you cant use your ebrake handle theres no cable hook up you might as well get a front kit and put your front calipers in the rear with some custom brackets</TD></TR></TABLE>
And how do you fix the severe brake imbalance from putting a caliper meant for the front on the rear?
Old Sep 10, 2007 | 08:39 PM
bb_one's Avatar
Default Re: K Sport big brake kit (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">
And how do you fix the severe brake imbalance from putting a caliper meant for the front on the rear? </TD></TR></TABLE>
dual calipers in the front of course
Old Sep 10, 2007 | 09:09 PM
del_parker's Avatar
Get some good pads, paint the H22 calipers whatever color you're looking for, and call it a day.
Old Sep 10, 2007 | 09:21 PM
Eddiebx's Avatar
some 6pots in the front, duh.
Old Sep 11, 2007 | 04:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">did you notice you cant use your ebrake handle theres no cable hook up you might as well get a front kit and put your front calipers in the rear with some custom brackets</TD></TR></TABLE>
Yeah I saw that, it concerned be at first, but I thought about it and figured I can come up with something to act as an e-brake.
Old Sep 11, 2007 | 05:23 AM
117's Avatar
117
Default Re: K Sport big brake kit (Eddiebx)
The number of pistons has nothing to do with the braking force output by the caliper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">some 6pots in the front, duh. </TD></TR></TABLE>
Old Oct 8, 2007 | 08:48 PM
AdReNaLiN's Avatar
Yeah I saw that, it concerned be at first, but I thought about it and figured I can come up with something to act as an e-brake.</TD></TR></TABLE>
Like what? You're gonna use a lever that controls a lil wooden stick like back in ur billy carting days?
Seriously man - think about what you're doing to your car here...
Old Oct 8, 2007 | 09:58 PM
MLBZ521's Avatar
Default Re: K Sport big brake kit (AdReNaLiN)
No need to bring up a month old thread to bash someone...
Old Oct 9, 2007 | 07:41 AM
NirVTEC's Avatar
[QUOTE=reptar_head]The car won't be autocrossed at all. It might see the drag strip once or twice. Other than that, it's just a daily driver/show car.QUOTE]
That says it all, Show car owners are weird...
Old Oct 9, 2007 | 10:00 AM
ImPuLsIvE's Avatar
I'm very happy with the 13" Wilwood kit I purchased from Fastbrakes.com
Wicked stopping power and great looks to boot
Old Oct 9, 2007 | 10:26 AM
NirVTEC's Avatar
Default Re: (ImPuLsIvE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImPuLsIvE &raquo;</TD></TR><TR><TD CLASS="quote">I'm very happy with the 13" Wilwood kit I purchased from Fastbrakes.com
Wicked stopping power and great looks to boot </TD></TR></TABLE>
Thats good....all he apparently cares about is looks....
Old Oct 10, 2007 | 06:34 AM
ImPuLsIvE's Avatar
Hmm, in that case, might as well try to find some of the old AEM big rotors that keep the OEM calipers.
They look like a big brake kit, just doesn't stop like one.
pcguy760
Suspension & Brakes
Sep 11, 2011 01:23 PM
h22 kid
Jul 28, 2009 04:44 PM
intxactdgsr
Oct 19, 2005 02:03 PM
clin20
Jun 7, 2004 08:30 AM
Katman
Feb 18, 2002 11:16 AM
