Blox throttle body problem
Old Sep 4, 2007 | 10:49 PM
NUISANCE's Avatar
Default Blox throttle body problem
I am having a problem mounting my Blox 68mm throttle body on my B16 head. When I mount it and connect the cable there isn't enough slack for it to close, it stays open. I have a GSR block with a B16 head and an old school Skunk IM. I have a Type R throttle cable and bracket. It's a throttle body for a B16.
Do I have to use a GSR throttle cable as it's a GSR? My BBK 70mm throttle body worked just fine but it's too big for my build up.
Old Sep 5, 2007 | 07:08 AM
all-mtr-teg's Avatar
Default Re: Blox throttle body problem (NUISANCE)
what other mods do you have to require a 68mm T.B.? Ported Head?
Old Sep 5, 2007 | 08:21 AM
NUISANCE's Avatar
Default Re: Blox throttle body problem (all-mtr-teg)
Fully built head with a full port/polish and high comp valves, Blox B cams, type R pistons. I was told to get this throttle body by the shop that is doing the build.
Old Sep 5, 2007 | 10:00 AM
Natural Aspirations's Avatar
Check the connection at the pedal.
Old Sep 5, 2007 | 06:15 PM
NUISANCE's Avatar
It's connected to the peddle as the BBK works fine.
What i mean is there isn't enough slack on the exposed part where you tighten it on the bracket on the IM. It's like I need an inch more of the exposed part for it to work.
Please help
HondaBurger
May 7, 2009 05:23 AM
namewasdallas
Mar 10, 2008 07:19 AM
thai-lorn
Aug 4, 2006 01:17 PM
Chango_racing
Jul 13, 2005 03:31 PM
