awkward idle
Old Sep 4, 2007 | 07:08 PM
H22Honda98's Avatar
Default awkward idle
i dont know if its just because its getting cold in the mornings, but i always let my car warm up for about 5 minutes, but this morning when it was warming up the idle was just bouncing. it would go up to abotu 2k then fall to about 1200. it did it about 50 times. stopped eventually, i just want to get it fixed if it will be a major problem. thanks for the help guys.
Old Sep 5, 2007 | 09:58 AM
slysi92's Avatar
Default Re: awkward idle (H22Honda98)
sounds like cold run valve or what ever they call it, it is located under and at the mouth of the tb. i had same problem. or check your coolant hondas will idle funny with low coolant. those 2 things i would check if it go's away when car is warmed up.
Modified by slysi92 at 12:27 PM 9/5/2007
Old Sep 5, 2007 | 10:36 AM
bluedlude's Avatar
Default Re: awkward idle (slysi92)
check your FITV(fast idle thermo valve).
Old Sep 5, 2007 | 05:25 PM
jdmlude5
Guest
Posts: n/a
here read threw this. its all in the faqs u jus gotta search.
https://honda-tech.com/zerothread?id=1979500
Old Sep 5, 2007 | 05:51 PM
dagle's Avatar
Default Re: awkward idle (jdmlude5)
agreed with FITV cuz i have the exact same idle bounce
matt_in_sd
Dec 14, 2006 11:58 AM
ick
Sep 11, 2005 10:46 PM
mafiaboy757
Jun 9, 2005 08:02 PM
4gen
Jan 11, 2004 05:28 PM
CRXhf90
Oct 1, 2002 01:58 PM
