94 accord dies, key hot and D4 loght blinks, will crank but dies when put in drive
Old Sep 4, 2007 | 07:06 PM
dkwaites's Avatar
Default 94 accord dies, key hot and D4 loght blinks, will crank but dies when put in drive
This is my Wife's car and I haven't been in the car when this happens. Car is running good but sometimes it will die. After coasting off the road you can crank but when you put it in drive,it is a automatic, the motor dies again. Wife says the D4 light blinks but I don't know what speed or how many time. She also said the ignition key is hot when she removed it. She heard a click of some type and I don't know where the sound comes from when the motor dies. The guy that does work on this car replaced the distributor, a relay, ignition switch and it still does this. We have also have the problem of the AC really putting a load on the motor to the point if you are at a low RPM the motor will stall but will crank and run if you turn the AC off and no D4 light blinking. Did I say this is my wife's car and she is pissed so I need HELP
Mr.Speed
Sep 8, 2011 05:04 AM
h23vtec_dc2
Dec 17, 2008 11:22 PM
chicows18
Jan 3, 2008 07:31 AM
GSRaCeRbOI
Aug 31, 2002 08:14 AM
