Buddy Club Spec 3 Cams -- Any problems?
Old Sep 4, 2007 | 06:29 PM
92integraVTECgsr's Avatar
Default Buddy Club Spec 3 Cams -- Any problems?
Im looking at putting some Buddy Club Spec 3 cams in my JDM B16. It is stock right now, but I just wanted to know if anyone has had any problems running them.
what would be a good valve spring to use with them? I was thinking supertech valve springs with supertech retainers.
This is my plan: BC3 cams, supertech valve springs, adj. cam gears, along with a tune via Hondata.
Sound good? Im thinking 20whp gain?
Old Sep 4, 2007 | 07:27 PM
1.8L_allmotormilitia's Avatar
I'm sure there is no problem running them with a good tune.
BC3 are like stage 1 cams so it should be good w/ your stock pistons.
good 160-170whp.
here is a thread with a gsr motor with BC3 cams.
https://honda-tech.com/zerothread?id=1508466
Old Sep 4, 2007 | 08:40 PM
all-mtr-teg's Avatar
Default Re: Buddy Club Spec 3 Cams -- Any problems? (92integraVTECgsr)
Good low and mid range gains, not so much top end as opposed to other brands like skunk. But i love my bc3 for my dd and i got blox type b's (sk2 stage 2 copies) in my weekend car.
Old Sep 5, 2007 | 10:05 AM
Default Re: Buddy Club Spec 3 Cams -- Any problems? (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Good low and mid range gains, not so much top end as opposed to other brands like skunk. But i love my bc3 for my dd and i got blox type b's (sk2 stage 2 copies) in my weekend car.</TD></TR></TABLE>
how long have you been running the BC3? any problems? what valvesprings are you using? got it tuned?
Old Sep 5, 2007 | 10:28 AM
satitus's Avatar
I put the BC3+ in my B16a and later in my b18c. Both had portflow springs/retainers. You definitely want to have them tuned. When I went from ITR cams to the BC3+ and was using a VAFC for tuning, I had to pull a ton of fuel out at VTEC xover with the BC3+. A dyno tuning session is mandatory, IMHO.
They did idle fine and drove well untuned on the small lobes though.
Old Sep 5, 2007 | 12:24 PM
had the bc3 cams for about 1 year and 3 months, 24k miles. supertech dual springs, stock retainers and keepers.
Old Sep 5, 2007 | 04:17 PM
which supertech valve springs? isnt there 2 different sets?
Old Sep 5, 2007 | 05:14 PM
cartune network's Avatar
i've had my bc3's for a lil over 2 years and no problems. im using skunk2 springs with um. i made really good gains with them. im also using them in a b18c5 not a b16 but u have decent compression so you should be fine with a set of springs and some cam gears. i made over 20whp with a tune. y does everyone say there close to stock? there 295 degree cams with an 11.xx mm lift. last time i checked honda didnt make anything like that. my setup made 216whp u should make really good gains if u have quality boltons.
Old Sep 5, 2007 | 05:19 PM
Default Re: Buddy Club Spec 3 Cams -- Any problems? (cartune network)
i do..
DC 4-2-1 Header, RSR ExMag, Carsound Cat, AEM CAI.
which skunk2 valve springs are you using? the original ones or the pro series?
Old Sep 5, 2007 | 06:35 PM
Dyno Dave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network &raquo;</TD></TR><TR><TD CLASS="quote">i've had my bc3's for a lil over 2 years and no problems. im using skunk2 springs with um. i made really good gains with them. im also using them in a b18c5 not a b16 but u have decent compression so you should be fine with a set of springs and some cam gears. i made over 20whp with a tune. y does everyone say there close to stock? there 295 degree cams with an 11.xx mm lift. last time i checked honda didnt make anything like that. my setup made 216whp u should make really good gains if u have quality boltons.</TD></TR></TABLE>
Nice setup and very good power from what people think is a small cam I use them in my basic B20 customer engines and everyone is very happy with the power and feel on the street.The BC3+ cams are a very good street cam in 1.6 to 2.0lt engines and I cant recommend them enough to my customers and as a min I use ITR valve train and have never had a problem.
Regards Dyno Dave
Old Sep 5, 2007 | 06:42 PM
pchan's Avatar
Default Re: Buddy Club Spec 3 Cams -- Any problems? (Dyno Dave)
i recently added them to my b16 with a short ram/dc-4-1 header and greddy sp2 exhaust. right now theyre at +2-0 and whenever i hit vtec it bogs down. definitly needs to get tuned. i talked to a tech rep of bc and they said to try going +1/-1 for now till i get it tuned with the ignition timing set at 12-14. i have supertech springs and crower chromoly retainers on em. cant wait to find out how much power i gain with what i got.
Old Sep 5, 2007 | 10:44 PM
Default Re: Buddy Club Spec 3 Cams -- Any problems? (pchan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyno Dave &raquo;</TD></TR><TR><TD CLASS="quote">
Regards Dyno Dave </TD></TR></TABLE>
yea i was really suprised with the outcome of the tune, i didnt think i was gonna make over 200whp lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">i do..
im using skunk2s original springs because i didnt wanna go over board with the pro series springs. the springs are great and there not expensive but u could probably run the bc3's with the stock itr valvetrain.
champLSinteg
Feb 22, 2008 11:29 AM
lowsiciv
Nov 28, 2006 12:27 PM
eg-ed
Aug 21, 2006 12:12 AM
b16vtecsol
18
Mar 4, 2005 08:06 PM
chinners10
Apr 24, 2003 08:38 PM
