Battery Offset adjustment for Precision 880's in CROME Pro?
CROME Pro plugin has battery offset values for Precision 680's and Precision 1000's. Both vary a bit in the offset tables. Does anyone know where I can source values for 880's, or a solution?
I assume with no values I'll just go with the 660's or 1000's offset values, but I suppose it won't be entirely accurate. Can anyone help me out?
Yeah, low impedance......
Well, essentially then i will just go with the 1000's values if that's the best solution here.
Thanks
Thanks
I am dealing with this with my rochester 1000cc's which are also PTE. and ive found through some research that the 880's and 1000's are the exact same body injector, just the nozzles are diff, so you can just use the 1000.
RACEPAK
Engine Management and Tuning
Apr 27, 2014 09:37 AM
Deatschwerks
Nov 15, 2012 10:22 AM
