Battery Offset adjustment for Precision 880's in CROME Pro?
Old 09-04-2007, 05:36 PM
RC000E's Avatar
Default Battery Offset adjustment for Precision 880's in CROME Pro?
CROME Pro plugin has battery offset values for Precision 680's and Precision 1000's. Both vary a bit in the offset tables. Does anyone know where I can source values for 880's, or a solution?
I assume with no values I'll just go with the 660's or 1000's offset values, but I suppose it won't be entirely accurate. Can anyone help me out?
Old 09-04-2007, 06:27 PM
Moderator in Chief
Muckman's Avatar
Default Re: Battery Offset adjustment for Precision 880's in CROME Pro? (RC000E)
Your 880s are probably low impedance right? So go with the offset for the 1000's offset.
Old 09-05-2007, 12:24 AM
RC000E's Avatar
Default Re: Battery Offset adjustment for Precision 880's in CROME Pro? (Muckman)
Yeah, low impedance......
Well, essentially then i will just go with the 1000's values if that's the best solution here.
Thanks
Old 09-05-2007, 02:17 AM
a1320honda's Avatar
I am dealing with this with my rochester 1000cc's which are also PTE. and ive found through some research that the 880's and 1000's are the exact same body injector, just the nozzles are diff, so you can just use the 1000.
Old 09-05-2007, 10:16 AM
RC000E's Avatar
Default Re: Battery Offset adjustment for Precision 880's in CROME Pro? (a1320honda)
Good good good....thanks for the confirmation...
MecanicaPR
07-06-2017 09:45 PM
RACEPAK
Engine Management and Tuning
04-27-2014 09:37 AM
raverx3m
14
12-07-2012 11:56 AM
Deatschwerks
11-15-2012 10:22 AM
three pac
11-14-2012 09:52 PM
Quick Reply: Battery Offset adjustment for Precision 880's in CROME Pro?
