Obd0 to Obd1 conversion, now fuel pump problems!!?!
Old Sep 4, 2007 | 05:23 PM
Hotori Hanso's Avatar
Default Obd0 to Obd1 conversion, now fuel pump problems!!?!
I just installed a rywire harness (from mr_crx i believe) , converted to an obd1 distributor, p72 ecu, soldered just the vtec wires. then when i went to start the car the fuel pump did not prime. i dont know what to do next. anyone know?
the plot thickens though. when i plugged in the far right plug into the ecu it would not go it. stupid me i tried to force it. when i pulled it out, one of the pins was bent. i bent it back pretty much straight. straight enough that i had a hard time telling which one was originally bent. when i plugged it back in it went in and clicked with no problems. but still no furl pump.
could this be the problem? anyone know what pin, on the ecu, reads the fuel pump?
Old Sep 4, 2007 | 06:11 PM
Crx Jimmy's Avatar
Default Re: Obd0 to Obd1 conversion, now fuel pump problems!!?! (Hotori Hanso)
it should not be related, unless the harness is pinned really wrong.
Old Sep 4, 2007 | 06:38 PM
90sedan's Avatar
Default Re: Obd0 to Obd1 conversion, now fuel pump problems!!?! (Crx Jimmy)
Have you checked for any blown fuses? Specifically the alt/sp fuse under the dash?
Old Sep 4, 2007 | 09:29 PM
Default Re: Obd0 to Obd1 conversion, now fuel pump problems!!?! (90sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan &raquo;</TD></TR><TR><TD CLASS="quote">Have you checked for any blown fuses? Specifically the alt/sp fuse under the dash? </TD></TR></TABLE>
im going to check.
and about the harness, its a rywire and all i have heard about them are good things. but who knows maybe im the 1 in a 10000 that got a lemon.
Old Sep 6, 2007 | 07:58 PM
if anyone has any other suggestions, let me know.
Old Sep 7, 2007 | 07:58 AM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hotori Hanso &raquo;</TD></TR><TR><TD CLASS="quote">
im going to check.
and about the harness, its a rywire and all i have heard about them are good things. but who knows maybe im the 1 in a 10000 that got a lemon.</TD></TR></TABLE>
Ryan knows his ****, i doubt its the harness. MAybe your main relay is toast?
Old Sep 7, 2007 | 08:06 AM
CRXBart's Avatar
Default Re: Obd0 to Obd1 conversion, now fuel pump problems!!?! (Boosted Chemist)
Ryan knows his ****, i doubt its the harness. MAybe your main relay is toast?</TD></TR></TABLE>
x2. Ryan could make those harnesses while sleeping. I would guess the main relay as well.
Old Sep 7, 2007 | 09:11 AM
dem0nk1d's Avatar
if you undo the conversion harness and plug in your stock ecu does it prime? because when you do the conversion the only thing that changes really is the dizzy. like 88-91 si is a 24 tooth crank angle sensor, a obd1 is something like 26. So in you still should be able to plug in the 88-91 si ecu and hear it prime up the pump. if not it's your main relay. take it apart and add new solder to all solder points.
Old Sep 7, 2007 | 09:12 AM
dem0nk1d's Avatar
unless it's a fault in the conversion harness. i just finshed my obd0 dpfi to the obd1 mpfi conversion a few weeks ago. it's simple.
Old Sep 7, 2007 | 09:33 AM
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">if you undo the conversion harness and plug in your stock ecu does it prime? because when you do the conversion the only thing that changes really is the dizzy. like 88-91 si is a 24 tooth crank angle sensor, a obd1 is something like 26. So in you still should be able to plug in the 88-91 si ecu and hear it prime up the pump. if not it's your main relay. take it apart and add new solder to all solder points.
Just an fyi, obd0=16 and obd1=24 teeth
Old Dec 1, 2007 | 01:36 PM
moho69's Avatar
i'm having the same problem, no fuel pressure. and all the dummy lights stay on when the key is in the on position. the relay clicks, but when i plugged in my old ecu, the relay started buzzing. any help would be appreciated
Old Dec 15, 2007 | 07:04 AM
Running925's Avatar
Default Re: (moho69)
bump for some answers
Old Dec 15, 2007 | 08:51 AM
SiR Inspired ED7's Avatar
My relay started buzzing also but that was after i got my ecu chipped... but he rechipped it & it was fine. But my jumper harness had the speed sensor in the wrong pin so i just switched it.
B16-CRX
Dec 22, 2010 08:26 AM
Project Phoenix
Jul 18, 2010 02:55 PM
B18CJDM ITR
Sep 19, 2005 04:13 AM
93_db2
Feb 23, 2005 04:50 PM
EKweezy
Sep 14, 2003 10:20 AM
