removing door mouldings on & rear tail lamps on EK hatch?
Old Sep 4, 2007 | 04:07 PM
kingrukus's Avatar
Default removing door mouldings on & rear tail lamps on EK hatch?
I am looking at prepping my 97 hatch for paint, and I need to remove the door and fender moulding strips, as well as the rear tail lamps. How do I do so? I am hearing I need to remove the interior panels, then push some clips out for the mouldings...
Thanks
Old Sep 4, 2007 | 04:09 PM
kingrukus's Avatar
Also does anyone know how to remove the black unpainted rocker trim along the bottom of the doors?
Thanks
Old Sep 4, 2007 | 04:22 PM
94dxman's Avatar
Default Re: (kingrukus)
for the rocker trim take off ur front mudflap and under the trim there are some screws on the bottom take them out and push it forward with ur hands to un-clip the trim
Old Sep 4, 2007 | 05:56 PM
JDean6pac's Avatar
Default Re: (94dxman)
bump because im curious to know how to remove the side moldings as well
Old Sep 4, 2007 | 06:16 PM
sniggler316's Avatar
Default Re: (JDean6pac)
It is easiest if you take the interior panels out first and push the clips from the inside. You'll see how when you get there. Tailights are easy. Move the carpet in the trunk away and there are four little nuts.
bouncy23
Mar 4, 2009 02:36 PM
16yroldekownr
Jun 30, 2008 08:45 AM
TC21
Jan 26, 2007 06:19 AM
ITRacer121
Jul 1, 2002 02:22 PM
DSC
Mar 4, 2002 08:34 AM
