Prelude on 15's?
Old Sep 4, 2007 | 01:38 PM
teg969's Avatar
Default Prelude on 15's?
im looking for some winter tires and i was wondering if 15's are a good fit for prelude?
because of the weight of the car i wasent sure if 15's are maybe too small?
i know stock are usually 16's....but a friend is willing to sell me his 15's at a good price...
if im not mistaking there 195/60/15
thanks
Old Sep 4, 2007 | 01:40 PM
street_ride14's Avatar
Default Re: Prelude on 15's? (teg969)
Go with 14's for the winter, MADDD acceleration yeYo
Old Sep 4, 2007 | 01:41 PM
E-Money's Avatar
I would try and run a 205/55/15 size. probably find a better selection of winter studs with that size.
Old Sep 4, 2007 | 01:48 PM
dwnsthGABOY's Avatar
Default Re: Prelude on 15's? (E-Money)
i'm not sure about the 5th gen, but the 4th gen came stock w/ 15's, so they deffinately r not too small.
Old Sep 4, 2007 | 03:22 PM
InvaderTrax's Avatar
Been covered so many times in the exact same situation. 15's will fit just fine, 14's are too small to clear the front brakes on a 5th gen
Old Sep 4, 2007 | 04:00 PM
prelude_h22vtec's Avatar
15s work great, even with the vtec rotors. i run the 205/50/15 but for winter i would run something a little bigger like the 205/55/15 or a 215/55/15 even
Old Sep 4, 2007 | 04:12 PM
Default Re: (prelude_h22vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_h22vtec &raquo;</TD></TR><TR><TD CLASS="quote">15s work great, even with the vtec rotors. i run the 205/50/15 but for winter i would run something a little bigger like the 205/55/15 or a 215/55/15 even</TD></TR></TABLE>
Wrong, better to use 195 width tire then a 215 for the winter. Think snow ...
Old Sep 4, 2007 | 07:19 PM
well i dont live in a snowy area, why not go wider?
Old Sep 4, 2007 | 07:23 PM
MilanoLude's Avatar
A smaller contact patch on icy roads is better for traction. The reason you ride/slide snowboards or skies down the mountain rather than just your shoes is because of the increased surface area on the snow.
Old Sep 4, 2007 | 07:41 PM
oh makes sense
Old Sep 5, 2007 | 08:15 AM
guessman's Avatar
works for mud tires too. the narrower the tire the fast you can cut though the mud, but we don't have that problem.
Old Sep 5, 2007 | 08:23 AM
NirVTEC's Avatar
Default Re: (guessman)
I rock 195/65/15's on my DD for winter.....cuts through snow like butter.
KILLS my acceleration on Dry pavement.....but I hang with the 4x4 crowd when it snows......
Old Sep 5, 2007 | 01:46 PM
Eddiebx's Avatar
yep when geting winter tires, i get the min i can go, for example i rock 185/65R15 on my snow rims
Old Sep 5, 2007 | 02:05 PM
E-Money's Avatar
Default Re: (Eddiebx)
but for keeping the speedo correct, you should run a 195/55/15?
Old Sep 5, 2007 | 02:31 PM
Eddiebx's Avatar
i dont konw thestock size of ur lude, but 195/55 sounds like civic/teg territory
i think ludes need 185/65, 195/60, 205/55 or so?
Old Sep 5, 2007 | 03:00 PM
A Blue Lude's Avatar
195/60 is a better match than 195/55 for a 5g. Dunno about the others.
Old Sep 6, 2007 | 07:24 AM
teg969's Avatar
Default Re: (A Blue Lude)
thanks fellas, the ski/snowboard analogie is killer thanks man!!
carnot
Jun 17, 2012 05:27 AM
RyanStevenPhillips
Jun 21, 2008 07:41 AM
Nathan007
May 25, 2004 07:15 PM
Djrockz415
May 23, 2004 03:01 PM
