brake light still on when e-brake off need help
Old Sep 4, 2007 | 08:38 AM
ekvtec's Avatar
Default brake light still on when e-brake off need help
i have a 2000 ej the problem is when i release my e-brake the light still have a little red glow to it i dont know what the problem is. the only thing i can think is the caliper going out or the master cylinder. i did a rear disc brake conversion using my stock propotion valve and cylinder and than 2 months that problem started can anybody help?
Old Sep 4, 2007 | 09:30 AM
MikeDawg's Avatar
Have you checked your brake fluid level?
Old Sep 4, 2007 | 10:24 AM
ekvtec's Avatar
yea i did, also i forgot to mention i change the brake pad and the metal bar that come out was hard to push back in the caliper
Old Sep 4, 2007 | 10:30 AM
cxSHOE's Avatar
Default Re: brake light still on when e-brake off need help (ekvtec)
check the switch pigtail under the ebrake area could be a bad/stuck ebrake switch, also to see if your pistons are stuck. just lift the wheels up and turn wheels. you should have alittle noise as you spin wheels, but very minimal. i dont think the piston have a sensor so to me it seems to be at the switch then to the cables. maybe the cable is stuck aswell.
hatchling37's Avatar
Have you checked the plug under your center console? Make sure the switch isn't being activated.
Old Sep 5, 2007 | 06:04 AM
ekvtec's Avatar
i've try that i even unplug it and the little red glow is still on. do i need to bleed all the brake fluid?
Old Sep 5, 2007 | 11:40 AM
shadowdancer's Avatar
my em1 was doing the same thing, it would stay on...and then when I pulled the ebrake up all the way, held it, then slammed it to the ground, it would turn off(sometimes it would have this baby glow to it). After driving about 3 miles, it would turn back on. I replaced the brake reservoir cap and it hasn't came back on ever since. I was told that the cap failure was a common problem.
yoni_69
Apr 12, 2011 01:21 PM
BigAnteg
19
May 21, 2009 05:44 AM
kkwick
Apr 22, 2009 11:35 AM
1kleenef
15
Feb 1, 2009 01:15 AM
nY's FiNeSt
Sep 6, 2004 08:17 PM
