Toda cam tuners Look Inside!!!
Old Jun 15, 2002 | 07:53 AM
Pinhead's Avatar
New User
Default Toda cam tuners Look Inside!!!
Ok, this Thursday my car gets tuned and I was wondering if there are any tuning tips you can give me that will help me get these things tuned perfectly...cam settings fuel settings etc....anything will help (Spec C's)
Old Jun 15, 2002 | 08:18 AM
qbsi's Avatar
Default Re: Toda cam tuners Look Inside!!! (Pinhead)
i think you can leave the exhaust at 0 or retard it a bit.
most people advance the intake to 3 or 4 degrees but you just have to run it on a dyno to get the most out of it.
good luck man and post the numbers yeah?
i still have to get my **** tuned too but i have ctr cams.
Old Jun 15, 2002 | 08:22 AM
sneakychaos's Avatar
Default Re: Toda cam tuners Look Inside!!! (qbsi)
Most people that I know advance the hell out of the intake cam... somewhere between 10 ~ 15 degrees. Retard the exhaust... a little at a time for finer tuning.
Old Jun 15, 2002 | 09:23 AM
lazyguy's Avatar
good luck keith take care of ur bussiness man
Old Jun 15, 2002 | 11:07 AM
qbsi's Avatar
Default Re: Toda cam tuners Look Inside!!! (b18cURmama)
do u turn the cam gears with the belt on or off ?
sort of new to tuning so i need as much info i can get . thnx guys
Old Jun 15, 2002 | 11:10 AM
Tommy_Gunns's Avatar
Default Re: Toda cam tuners Look Inside!!! (trooth)
I thought Toda advise not to advance or retard the timing (exhaust or intake) past 5 degrees or you'll have clearance issues?
Old Jun 15, 2002 | 11:17 AM
shirubia's Avatar
Default Re: Toda cam tuners Look Inside!!! (Tommy_Gunns)
I thought it was that way for most cams as well
Old Jun 15, 2002 | 02:53 PM
JDM_DOHC_SiR's Avatar
New User
Start with this and then work around it...
VTEC 6800~7000
When the high cam kicks in add +4/+5 fuel
also add a tad bit fo fuel on the low cam between 3~5.5
start off with the ex cam @ 0 and the intake @ 0~+1
See if that works for ya'
it's a starting point at least good luck
Old Jun 15, 2002 | 03:33 PM
FAST94GSR's Avatar
New User
Default Re: Toda cam tuners Look Inside!!! (JDM_DOHC_SiR)
10-15 degrees advance on the intake cam.
Seriously are you smoking too much crack or weed?
Old Jun 15, 2002 | 09:56 PM
New User
up
Old Jun 15, 2002 | 10:48 PM
Black R's Avatar
25 Year Member
Default Re: Toda cam tuners Look Inside!!! (FAST94GSR)
.....I'm at +15,-5 right now.
It all depends on what compression, pistons you're using.
I know someone else who was at ~ +5,-10 and was using ctr pistons.....
Old Jun 15, 2002 | 10:56 PM
New User
Default Re: Toda cam tuners Look Inside!!! (Black R)
???? Say what..??!
Old Jun 17, 2002 | 09:42 AM
topspeed86's Avatar
Who's tuning it for you is it running good let me know.
Chris
Old Jun 17, 2002 | 10:34 AM
Nate B's Avatar
Default Re: Toda cam tuners Look Inside!!! (topspeed86)
on my setup I retarded the exhaust -1 and advanced the intake +2 run smoothly and strong as hell.
Old Jun 17, 2002 | 10:37 AM
Mike K's Avatar
Default Re: Toda cam tuners Look Inside!!! (KILLERB18)
Not sure what settings would be good. But that is why you're going on the dyno!
I'm sure John knows what he is doing, and he'll treat you right.
Old Jun 17, 2002 | 11:13 AM
Padawan's Avatar
Darth ModerVader
Default Re: Toda cam tuners Look Inside!!! (Mike K)
On the cams that are advanced ~ 15 degrees, is it possible that the belts are one tooth off? I remember reading how many degrees each tooth is, and I assume it would be more than 15, but 15 degrees advance seems pretty excessive.
Old Jun 17, 2002 | 11:16 AM
Austin's Avatar
Default Re: Toda cam tuners Look Inside!!! (Spec.R 00-0123)
I had my spec B's at +5, -5 before I removed them...I didn't want to go farther than that as I had not pulled the engine apart and clayed the pistons and did not know what my upper limits were before piston-->valve contact.
Austin
Old Jun 17, 2002 | 11:50 AM
MPH's Avatar
MPH
New User
Default Re: Toda cam tuners Look Inside!!! (Austin)
Hey Austin,
When moving the cam gears did your tq curve move around? I can't move my tq around at all.
Old Jun 17, 2002 | 12:07 PM
Austin's Avatar
Default Re: Toda cam tuners Look Inside!!! (MPH)
Hey Austin,
Adjust your fuel after you make your changes...that's how I was able to gain power.
Old Jun 17, 2002 | 12:12 PM
TodaSi's Avatar
Ditto. (What Spec.R 00-0123 said)
Something is wrong there.
[Modified by TodaSi, 4:13 PM 6/17/2002]
MPH's Avatar
MPH
New User
Yes I adjust fuel, but I always here of people moving tq curves around but I can't seem to do it. My exhaust cam is useless. It makes no power no matter what I do with it. My intake cam loves advance but the furthest I went was +4.
Old Jun 17, 2002 | 12:17 PM
sgT's Avatar
sgT
Default Re: Toda cam tuners Look Inside!!! (TodaSi)
The last car I tuned was spot on at 0,0 as was shown by the PERFECT idle.
But after tuning was at +15, +10. Go figure
Old Jun 17, 2002 | 12:19 PM
Mike K's Avatar
Default Re: Toda cam tuners Look Inside!!! (sgT)
Listen to Steve. He knows what he is talking about.
Oh, and Steve.. about those ITR pistons you wanted for your B20 buildup, I have them in stock. Let me know if you want them in standard or oversized. LOL.
Old Jun 17, 2002 | 01:13 PM
Padawan's Avatar
Darth ModerVader
What kind of cams were they Steve?
Old Jun 17, 2002 | 01:21 PM
Pinhead's Avatar
New User
hey Mike K, what were the max I could go on my cam gears again? I forgot and I just wanna make sure I have room...+15 -15???
