Running on 3 cylinders on H22A4 Swap. Help!!
Old Sep 3, 2007 | 08:29 PM
oneprelude's Avatar
Default Running on 3 cylinders on H22A4 Swap. Help!!
Ever since I swapped the H22A4 into my 4th gen Prelude, the car ran good for a week, then one of the cylinders died. Right now I'm running on 3 cylinders. I've replaced: Fuel filter, cap and rotor, distributor external coil, spark plug cables, spark plugs. Replacing these do not solve the problem. Is it possible because of the injectors (I'm using the OBDII injectors) or the fuel pump??
Help is appreciated, thanks
Modified by oneprelude at 9:44 PM 9/3/2007
Old Sep 3, 2007 | 08:46 PM
98vtec's Avatar
moderator emeritus
Default Re: Running on 3 cylinders on H22A4 Swap. Help!! (oneprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneprelude &raquo;</TD></TR><TR><TD CLASS="quote">Ever since I swap the H22A4 into my 4th gen Prelude, the car ran good for a week, then one of the cylinders is dead. Right now I'm running on 3 cylinders. I've replaced: Fuel filter, cap and rotor, distributor external coil, spark plug cables, spark plugs. Replacing these do not solve the problem. Is it possible because of the injectors (I'm using the OBDII injectors) or the fuel pump??
Help is appreciated, thanks</TD></TR></TABLE>
have you tried a valve adjustment?
put a long screwdriver to each injector and put your ear to the screwdriver and listen for ticking.
Old Sep 3, 2007 | 09:09 PM
vinuneuro's Avatar
Default Re: Running on 3 cylinders on H22A4 Swap. Help!! (98vtec)
Remove the plug wire and check for spark. You'll either rule the ignition system out, or find the problem. Like 98vtec said, valve adjustment should be routine maintenance.
Old Sep 3, 2007 | 10:12 PM
badassmthr4000's Avatar
Default Re: Running on 3 cylinders on H22A4 Swap. Help!! (vinuneuro)
well i know you prolly have already done this but make sure the fuel injector to that cylinder is fully pluged in on top of the other checks. it wouldnt be the first time someone has done it.
Alexander Smets
Jul 26, 2019 06:50 PM
neeks
Jul 6, 2005 04:31 PM
Ass_Clown
Nov 27, 2003 04:29 PM
g2turbo
Oct 2, 2003 07:53 AM
