Clutch Troubles
Old Sep 3, 2007 | 08:00 PM
jcoosi's Avatar
Default Clutch Troubles
I have been having troubles when I stage and begin to preload at 6k-7k my car starts pulling foward.The pedal is pressed all the way to the floor.I have checked thrust on the crank its good,replaced slace cyl it was leaking,tried 3 different clutch and flywheel combos,and adj the clutch rod both ways and no change.Currently have a clutch masters s5 4 puck unsprung w/ exedy flywheel.Also the pucks on the first 2 clutches were ate up.WTF I'm tryin to get fixed so I can go get my race gas tune.
General info:
2000 si
gsr block w/ ls crank
si tranny
Old Sep 3, 2007 | 08:30 PM
2wheelhunter's Avatar
Default Re: Clutch Troubles (jcoosi)
may sound a little simple but theck the clutch line (bleeding it a few more times, fork and clutch MC... if these are all checked i'd think perhaps the pilot bearing?
Old Sep 4, 2007 | 04:38 AM
jcoosi's Avatar
Default Re: Clutch Troubles (2wheelhunter)
New pilot bearing and clutch fork looks good.Im going to try a master cyl just for s&g Thanks for the advice
Old Sep 4, 2007 | 07:25 PM
boostedcivicsir's Avatar
Mr. Badwrench
make sure you have the correct free play. if it isnt fully disengaging, it will lurch forward.
Old Sep 4, 2007 | 08:29 PM
jcoosi's Avatar
Default Re: Clutch Troubles (boostedcivicsir)
ive checked it and rechecked it going to put on a mc tomorrow and see how it goes.
Old Sep 5, 2007 | 08:48 AM
CHUCKY's Avatar
if it's a built motor it might not be balanced right and thats causing the kreep at the light
Old Sep 5, 2007 | 01:04 PM
jcoosi's Avatar
Default Re: (CHUCKY)
I had the rotating assy balanced before installed and this problem is a recent thing it didnt have this problem after the tune.In fact i didnt get this problem until the first s5 clutchmasters shated on me.Since then its been one thing after another
Old Sep 6, 2007 | 04:39 AM
jcoosi's Avatar
Default Re: (jcoosi)
Thanks guys for the help but I found out what the culprit was I had a broke crankshaft on the main closest to the flywheel.
MiNeSEK
19
May 11, 2013 12:05 AM
jdmcivicracer89
21
Jun 5, 2008 09:39 AM
b20integrapower
May 17, 2006 02:16 PM
Sinner
Mar 24, 2004 04:50 PM
fiebru1119
Aug 20, 2002 10:07 AM
