Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Problem with 02 Civic headlight bulbs
Old Sep 3, 2007 | 07:57 PM
gen5accstilez's Avatar
Default Problem with 02 Civic headlight bulbs
Hi HT. The problem with my fathers 02 civic is that the low beam on the passenger side headlight is out. What confuses me is that the high beams work.. The 02 civics only use one light bulb for high and low beams right? because i only see one socket. Is it possible for the low beam to stop working, while at the same time hight beams work? Should i go ahead and replace the bulb, or is there some other problem that i should know of?
Thanks in advance.
BTW i drive an 95 accord, which has separate bulbs for low and high. Which is why i am unsure about the civic.
Old Sep 3, 2007 | 08:13 PM
K24_Y61P's Avatar
Default Re: Problem with 02 Civic headlight bulbs (gen5accstilez)
its one bulb yes, but there 2 elements in the bulb, high and low. you need a new bulb.
Partizan
Lighting
Oct 27, 2008 02:37 PM
civic-cpe
Lighting
Sep 20, 2007 08:11 PM
CivicVelox17
Jan 2, 2007 10:11 PM
Tone_Locs Dc2
Honda Motorcycles
Jul 19, 2005 07:34 PM
puckster02
Mar 11, 2002 07:19 AM
