Timing Belt Tension...slack
Old Sep 3, 2007 | 07:15 PM
lude98SH's Avatar
Default Timing Belt Tension...slack
I installed the h23 manual tensioner along with removing the balance shafts. I believe i tensioned the belt properly however it seems to have alittle slack in the front on the long stretch from the exhaust cam gear to the crank but everywhere else is tight as can be. Just wanna make sure thats how its supposed to be.
Old Sep 3, 2007 | 07:19 PM
Obama's Avatar
Default Re: Timing Belt Tension...slack (lude98SH)
i noticed when i did the h23 tensioner conversion, there was no slack at all and was very tight (more snug than stock, and alot harder to get on) but its been about 7-800 miles and its fine
Old Sep 3, 2007 | 08:00 PM
98vtec's Avatar
moderator emeritus
Loosen the tensioner. Hold the intake cam gear with a 14mm wrench. Spin the crank counterclockwise while holding the intake gear from spinning. At the same time, tighten the tensioner. it helps to have a friend. This will take all the slack out.
Old Sep 4, 2007 | 05:27 PM
lude98SH's Avatar
Default Re: Timing Belt Tension...slack (98vtec)
so i should have zero slack even on that long run up front ?
Old Sep 4, 2007 | 05:43 PM
98vtec's Avatar
moderator emeritus
there will be some slack. I once read on here that you should be able to turn the belt 90 degrees.
Old Sep 4, 2007 | 06:02 PM
lude98SH's Avatar
hmm i might be ok then .....ill post a pic up tomorrow or something.
Old Sep 4, 2007 | 08:55 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">I installed the h23 manual tensioner along with removing the balance shafts. I believe i tensioned the belt properly however it seems to have alittle slack in the front on the long stretch from the exhaust cam gear to the crank but everywhere else is tight as can be. Just wanna make sure thats how its supposed to be. </TD></TR></TABLE>
Some slack is normal. There is even an aftermarket piece you can install for High performance H22's in order to reduce belt flap that is common on that side...
Old Sep 4, 2007 | 11:34 PM
Finest's Avatar
Default Re: Timing Belt Tension...slack (ziptie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ziptie &raquo;</TD></TR><TR><TD CLASS="quote">
i noticed when i did the h23 tensioner conversion, there was no slack at all and was very tight (more snug than stock, and alot harder to get on) but its been about 7-800 miles and its fine</TD></TR></TABLE>
Same here. It was a little difficult getting the belt on, but removing the rear tensioner bracket made a world of difference.
hyabusa hunter
Feb 17, 2007 07:59 PM
h22aseemsgood
Nov 14, 2006 06:53 PM
flip1199
Apr 4, 2005 08:57 AM
EGhatch22
Dec 28, 2004 06:45 AM
phil2000
Aug 29, 2003 11:06 PM
