pictures of B16 motorswaps?
Hey, could you guys please post up pics of the engine bays in your B16 hybrids? I've performed the swap, but I wanna double check my vacuum line routings.... I think they're currently wrong... Thanks!!!
Dan
Dan
here are some pictures of my vacuum hose configuration
basicly the one that is in red, went off the fpr and i used a t fitting and hooked it into the back. let me know if u have any questions
on that pic it has two solenoids and on obd-0 cars only has one how would you go about the lines if you only got one...and does those vacum make you car slower if it's mixed up (exept the fuel regulator's line)
Well I have to check a few things. I thought the fpr needed to be tied into the map sensor. That is currently how I have mine configured. Maybe that is why my car bogs on almost closed and part throttle crusing. I am going to change over to this and see if it improves anything.
it also depends on which B16 you have..the 1million series (integra) B16s have more vacuum lines coming off the intake manifold. when i did mine i had the 5million series (civic/crx) B16. don't know how much this'll help..
the two lines near the back side of the manifold i teed together. i tried to go by the diagram shown above as much as i could..oh, for the dashpot there is supposed to be a line going onto the air intake, but i left my off and it's fine. if you still need more info i can take a pic tonight.
there's a dashpot connected to the throttle body correct? if that vacum line is not connected thats fine right? what about the diaphram right next to it with the word up on it where does that vacum line go .It usually goes to the intake but i have an after market intake can i just remove it( the diaphram with the word up on it) ??
[Modified by 90SIhybrid, 4:48 AM 6/21/2002]
91hatch_on17's
11
Mar 3, 2005 07:06 PM
