Help with noise in front end.
Old Sep 3, 2007 | 02:55 PM
GYChris's Avatar
Default Help with noise in front end.
first off, i have a 92 civic dx hatch (d15b7)
when not accelerating, or when slowing down (brake or without brake) i can hear a clicking noise (it slows down as i slow down, so i know its in the drivetrain.) it almost sounds like a cv axle. i know usually worn cv axles can be heard while turning but do they ever produce the symptom i am experiencing? if not, what could it be?
thanks, in advance, for your help.
Modified by EGchris at 5:01 PM 9/3/2007
Old Sep 3, 2007 | 04:15 PM
rockworker's Avatar
Default Re: Help with noise in front end. (EGchris)
This may or may not be what you are experiencing, but......I had a similar noise that was driving me crazy on my 2000 Civic LX. It seemed to be in the front end, passenger side when driving between 30-45 mph, regardless of braking or not.
I put the car up on lifts and crawled under it. Turned out it was the remains of part of the splash guard under the wheel well. One screw was holding the thing on and it was flapping in the wind at certain speeds. I took it off and discarded it and the problem went away. Hope yours is as simple!
Old Sep 3, 2007 | 04:16 PM
RCautoworks's Avatar
Could be the power steering rack busings going bad, or it could just be a bad axle. Yes they can click when going straight.
Old Sep 3, 2007 | 04:30 PM
GYChris's Avatar
Default Re: Help with noise in front end. (RCautoworks)
yeah the car has 230k miles on it so its probably a maintenance problem, im just not sure which. i know its not a splash guard because the noise goes with the speed of my vehicle, the slower i go, the slower it clicks and vice versa. but thanks for the help rockworker
can cv axles click without the boot being ripped? seems like they could i guess if they are worn out enough.
thanks for the replys
Old Sep 3, 2007 | 04:34 PM
Yes they can make noise and look fine
Old Sep 3, 2007 | 04:46 PM
GYChris's Avatar
alright, simple enough. is there a way to determine if a cv axle is done with? (when the boot is ok)
Old Sep 3, 2007 | 07:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGchris &raquo;</TD></TR><TR><TD CLASS="quote">alright, simple enough. is there a way to determine if a cv axle is done with? (when the boot is ok)</TD></TR></TABLE>
Not really, besides driving it and taking tight turns and see if it clicks more.
RG5384
Apr 29, 2013 12:59 AM
CivicSweetie01
Honda Civic (2001 - 2005)
12
Mar 9, 2012 04:11 AM
smokestack
Nov 19, 2011 01:38 PM
knakmuhs
Suspension & Brakes
Aug 21, 2010 02:19 PM
knakmuhs
Aug 19, 2010 10:34 AM
