Dumptube fabrication. Anyone use the flexible exhaust stuff?
Old Sep 3, 2007 | 02:27 PM
TurboEM1's Avatar
Default Dumptube fabrication. Anyone use the flexible exhaust stuff?
Hey guys. I need to fab a dumptube for my car. I have seen it mentioned that some people use the flexible exhaust piping that they sell at autozone like this.
I mean I am sure its not ideal but how well does it work? Worth doing? It wouldn't be permanent but maybe a month or two untill a make a dumptube.
Thanks
Old Sep 3, 2007 | 02:51 PM
carrnut21's Avatar
bump i would also like to know i will need to make a dump tube in the future and this looks easy
Old Sep 3, 2007 | 03:10 PM
RCautoworks's Avatar
Default Re: Dumptube fabrication. Anyone use the flexible exhaust stuff? (TurboEM1)
Yes I have seen people use it. Works fine
Old Sep 3, 2007 | 04:19 PM
slooogsr's Avatar
hmmmm, might be a cool option to help route a dump behind the front tire.......... may give it a shot.......
Old Sep 3, 2007 | 04:26 PM
90dxhmt's Avatar
Default Re: (slooogsr)
Works just fine, doesnt look overally baller but will get the job done
Old Sep 3, 2007 | 05:43 PM
blackeg's Avatar
Default Re: (90dxhmt)
yeah it works. ive run it before and have a friend currently using it. you cant really weld it but to extend your dumptube or something it will work. ive never run it right off the wastegate, i dunno if that gets too hot for it or not
Old Sep 3, 2007 | 06:55 PM
rwcdrums's Avatar
Default Re: (blackeg)
yeah I use it so does my buddy. I painted mine flat black with some high heat paint and it seems to hold up. It works fine and is cheap.
Old Sep 3, 2007 | 07:07 PM
turbosol18's Avatar
Default Re: (rwcdrums)
ive ran it before and it works as any other dump pipe..think about it, its an exhaust pipe ment for gases and heat, why would'nt it work?
also to add to that its not like its always being heated up its only when you hit full boost but yes it works just as well, IMO doesnt look as good but gets the job done the same way
Old Sep 3, 2007 | 07:28 PM
alpha's Avatar
We have ran these on a couple cars. I actually ran one on my personal car. Cut, tig welded and ran past my oil pan. Quick, easy and worked great
dfoxengr
Welding / Fabrication
29
Dec 18, 2007 10:00 AM
*Boostwerks*
47
Jul 2, 2006 05:53 AM
MJT805
Nov 14, 2005 02:39 PM
pK1spooled
10
Aug 22, 2005 08:24 PM
DRAGLS
Feb 28, 2005 06:18 PM
