Plug recommendations for H22/E85
Old Sep 2, 2007 | 10:05 AM
purpleh22's Avatar
Default Should same plugs and gap be used with E85 as gasoline?
I recently had my engine retuned for E85. I had been running 113 octane race gas. I used Bosch plugs (BKR7E-11) with the race gas. With E85, I assume that the engine is running cooler. Should I be running a different heat range?
H22, fully built, Arias 10:1, MSD Digital6, GT30, Coolingmist methanol/H2O spray triggered @ 8psi, 3" exh., I'm using 10 psi and 17 psi settings. Seems to run fine with the 7s but I'm not aware of what plug readings on E85 would look like. 439 whp @ 17 psi
Modified by purpleh22 at 9:00 PM 9/3/2007
Modified by purpleh22 at 9:04 PM 9/3/2007
Old Sep 2, 2007 | 10:40 AM
thomas@LPS's Avatar
i just recently retuned on e85 as well... after a few 16psi on bkr7e the plugs looked a little cold but im not exactly sure what to look for... in for some answers as well.
Old Sep 3, 2007 | 02:04 AM
purpleh22's Avatar
Default Re: (civic_ex_95)
Anyone with experience on this? Also, should plug gap be changed? I have it set at .28.
Modified by purpleh22 at 7:23 AM 9/3/2007
Old Sep 3, 2007 | 08:02 PM
purpleh22's Avatar
Default Re: (purpleh22)
Anyone with E85 experience? Generally will plugs used with E85 need to be a hotter range than those used with gas/race gas at the same boost level? Any gap difference?
patroick67
Mar 13, 2012 07:59 AM
1slowcrx
Sep 10, 2011 05:38 PM
adiDAs
Engine Management and Tuning
Oct 2, 2009 04:42 AM
purpleh22
Sep 4, 2007 07:02 AM
TurboMiata
Apr 10, 2005 09:29 AM
