intake air temperature sensor(IAT)
It is on the back of the intake manifold.
Going from left to righ you should see your MAP sensor on top of the throttle body, then the Intake Air Control Valve (IAC) and the Intake Air Temperature (IAT) Sensor. Both the IACV & IAT are on the back of the plenum between the intake manifold and the firewall.
