Front Motor Mount Bolts!
Old Sep 3, 2007 | 12:20 PM
Mr.Luder's Avatar
Default Front Motor Mount Bolts!
So There are 3 Bolts hold the front motor mount to the block. There is 2 on top and 1 right below those 2. The 1 right below the 2 stripped and won't go back in. Will that cause in problems and how do i fix it? The hole in the block stripped. Don't ask me how cause I found it like that. Me and a few buddies where removing the bolts and found the bottom one hard to remove. Come to find out the threads are stripped in the hole. Can I run the car like that with only two bolts?
Old Sep 3, 2007 | 12:23 PM
snowblind7x's Avatar
Default Re: Front Motor Mount Bolts! (Mr.Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder &raquo;</TD></TR><TR><TD CLASS="quote">So There are 3 Bolts hold the front motor mount to the block. There is 2 on top and 1 right below those 2. The 1 right below the 2 stripped and won't go back in. Will that cause in problems and how do i fix it? The hole in the block stripped. Don't ask me how cause I found it like that. Me and a few buddies where removing the bolts and found the bottom one hard to remove. Come to find out the threads are stripped in the hole. Can I run the car like that with only two bolts?</TD></TR></TABLE>
id recommend getting the innovative mounts since you know its safe to run those without a front mount at all. Other then that i guess your only options are running it with just 2 bolts or re-tapping the threads in the block.
Old Sep 3, 2007 | 01:37 PM
117's Avatar
117
Install a HeliCoil kit to repair the stripped threads.
Old Sep 3, 2007 | 02:19 PM
Chris F's Avatar
I only run one bolt in the front mount. It's free lightening.
But seriously, it'll be fine. You might want to fix it for peace of mind.
-Chris
Old Sep 3, 2007 | 08:00 PM
Mr.Luder's Avatar
Thanks Guys!
shytdoode
Jun 3, 2009 02:06 AM
gnccracer20
Mar 19, 2009 06:04 PM
byc95eg
Dec 9, 2008 11:32 AM
