Back from Palmdale...
Best time I got was 15.0 @ 92MPH with a 2.2 60ft time. Setup is 92 hatch w/ gsr motor (intake/exhaust). Tires: 13'' vx wheels w/ bald stock tires. I'm still surprised I was able to pull off a 2.2 60ft. Spin like crazy when I shift into 2nd, as well as mad wheel hop. I think it's time to upgrade the wheel/tire combo. What do you guys recommend? What times do you think I'll be pulling off at a "good" track?
-Rod
-Rod
Best time I got was 15.0 @ 92MPH with a 2.2 60ft time. Setup is 92 hatch w/ gsr motor (intake/exhaust). Tires: 13'' vx wheels w/ bald stock tires. I'm still surprised I was able to pull off a 2.2 60ft. Spin like crazy when I shift into 2nd, as well as mad wheel hop. I think it's time to upgrade the wheel/tire combo . What do you guys recommend? What times do you think I'll be pulling off at a "good" track?
-Rod
-Rod
if for drag only , get 2 steelies and slap some m/t slicks 14x20x8, works wonderful
or you can use the rims from miata (which there lighter) they just a need a little mod to fit the car perfect , no bid deal doh
That sounds good...but for now...i wanna see what I can do on street tires. Once I think I've pushed the limit on street legal rubber...then I'll start on slicks.
really? wow.....is palmdale that bad? Dont mean it in a bad way but your hatch with a gsr should be running better times, maybe its just the elevation and heat
[Modified by eg_nezay, 8:09 PM 6/15/2002]
I can't really say how BAD palmdale is because I haven't been to any other track...so I don't know what times I'd pull somewhere else. I'll try to give you an idea by other times I've seen:
CRX w/b16: 15.9
92 hatch w/gsr i/h/e: 15.7
2000 SI: mid-high 16s
Never neon: 18s
I raced some dude a couple of times....he had a vx like me, with gsr motor, intake, jdm dc header, exhaust, better tires/suspension dialed...15.0-15.4.
-Rod
CRX w/b16: 15.9
Never neon: 18s
-Rod
palmdale is a second slower cause of altitude
So do you think I can run low 14s?
I raced a guy with a blue eg (had a cf hood...don't remember the rims) 3-times...cool guy. Other cars that I remember:
Red Tacoma
Silver Neon
2 Eclipses (gsts i think)
Maxima
-Rod
Red Tacoma
Silver Neon
Maxima
-Rod
i got to the track at 8:00 i only raced 3 times. i ran 17.5 but i got a lot of wheel spin(should have ran high 16's)
civic si Hatch-lost
civic cx-lost
hyundai tiburon- won
civic si Hatch-lost
civic cx-lost
VX rims are nice...haha i could remember my friend taking his VX HB out to carlsbad with stock tires stock 13'' VX rims and stock suspension.. ran 14.1@100mph w/ b16... the front end looked like it was going to shake off
hey try gonig to carlsbad... i hate seeing how cars perform at palmdale
at pamdale do to the elevation and the track
you can knock easy about 1/2 a second.
also if you compared to other tracks , yes pamdale sucks . but is good for practice and to also see your improvements
