help!!! 92 civic d15!! plzzz help me!!
Old Sep 3, 2007 | 10:25 AM
x_robert_miner_x's Avatar
Default help!!! 92 civic d15!! plzzz help me!!
ok i have no idea what is happening!?!?
bout 3 weeks ago. i put in a new exedy clutch and flywheel, it was running strong for 2 weeks, then out of no where one day i couldnt start it so i figured my battery was dead, so i left it home 2 b charged. then i get a call from my brother sayin that he tried 2 move it and at first it just wouldnt move? and then he turned it off and tried again and released the cluth and it moved a lil then the whole front end went down, and it wouldnt move even when it was in gear.
since the new clutch was added. i got a new transmission, a new cv axle. and still nothing. everything is brand new. i am really stumped.
as of right now i can start it up, it goes into gear but just wont move nothing not reverse no first it just sits there and revs. i really need some help. could it b a faulty clutch?? flywheel?? plz help if u could any suggestions would b very helpful.
Old Sep 3, 2007 | 10:31 AM
cmiller219's Avatar
Default Re: help!!! 92 civic d15!! plzzz help me!! (x_robert_miner_x)
have u tried putting it in 2 gear and seeing if it works it might be the 1st gear? but u did say it was reverse to so i dont know i can ask around.
Old Sep 3, 2007 | 10:35 AM
Default Re: help!!! 92 civic d15!! plzzz help me!! (cmiller219)
yea i tried everygear, i have no idea wuts going on man. i asked everyone.
it just doesnt make sense.. completely new clutch and flywheel(exedy). new cv axle. new transmission.. so i dont kno unless my clutch is faulty? or my somehow my pressure plate is gone...
Old Sep 3, 2007 | 11:05 AM
cmiller219's Avatar
when u put it into gear and try to take off does it just rev or give any noise or does it just cut off? or does it act like it want to go but shut down?
Old Sep 3, 2007 | 12:03 PM
it just revs.
Old Sep 3, 2007 | 12:14 PM
instrument's Avatar
sounds like you have a broken axle
Old Sep 3, 2007 | 12:27 PM
95dxsir2's Avatar
Default Re: (instrument)
shift linkage?
Old Sep 3, 2007 | 12:29 PM
maxpsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you have a broken axle</TD></TR></TABLE>
Or the axle could have popped out. This could be due to the c-clip on the axle or a worn down differential. If it isn't externally apparent what the problem is, you may have to remove the trans.
Old Sep 3, 2007 | 12:32 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (maxpsi)
Yup, sounds like one of the axles popped out. It happens to the best of us. If that's not the problem, check the pressure in the clutch system to make sure both of your cylinders are okay.
juxahondaguy
Transmission & Drivetrain
Jul 14, 2015 05:45 PM
wolve
Apr 29, 2009 07:40 PM
civiceg94
72
Jul 10, 2007 09:51 PM
.Nomad.
11
Aug 5, 2006 09:08 PM
