Brake question?
Alright, I have a 1995 Honda Civic Si Hatch with upgraded brakes and rotors, has Integra Calipers and Cross drilled slotted rotors FTL. Never had any problems before but suddenly the other day I drove it and the front right brake makes like a clanky sound the faster i go the faster it gets but the slow i got the slower and louder it gets, does anybody have any ideas?
Oh can someone help me on how to fix a broken stud on my rear drivers side?
you cant see it too well its the rear one though
The noise your actually probably hearing is your wheel bearing going bad. As for the rear; Its fairly simple; all you need to do is remove the wheel; remove the drum(i think you should still have drums) and bang out a stud; and pull one back inwith a lugnut and a few washers
also when taking off the drum make sure ebrake isn't pulled... you won't be able to get the hub off... (it happened to me and at first i couldn't figure out why i couldn;t get it off... and said wheel bearing which might be the case but check the front calipers and the front brake pads make sure that they aren't loose
i lost a break pad while driving because it wasn't clipped in right... couldn't figure out what the clanging was until i had no breaks and no more clanging
miamirice
Oct 3, 2011 04:05 PM
cccya
Oct 25, 2002 06:06 PM
