turbo ef question
Old Sep 3, 2007 | 04:34 AM
Wink1100's Avatar
Default turbo ef question
got a d16z6 on turbo I just put together. have a problem with the map code coming on ecu. I'm only running 7-5psi and are running stock injectors. not a big turbo at all. budget. any ideas on how to get rid of the light. seems to happen under load and sometimes comes on starts up. installed a one way check valve in the vacuum lines but, seems not to make a difference. I wanna get rid of this light! idle drops badly and stalls when light is on too. will a motorola map sensor work? i'm using the firewall map assembly. any help would be great. thanks
CorrodeONE
Jun 11, 2008 07:30 PM
Wink1100
Sep 3, 2007 06:39 AM
Wink1100
Sep 3, 2007 06:32 AM
NOSED_CRX_VTEC
Oct 18, 2002 06:07 AM
