cat converter question..
Old Sep 3, 2007 | 03:05 AM
SIDEXIT's Avatar
Default cat converter question..
i know i did the search and all cat threads didn't answer my question..
but my cat has gone out on my 2000 honda civic ex. not completely but it makes a growling noise like broken particles are inside. well i passed inspection right before it starting making noise. it sounds like im turbo or something. no cel is on at the moment, yet. i need this fixed.
so my question is, is there any oem/hi-flow replacement cat converters that will pass inspection next time? other than buying a oem one. cause those things can be $$$
and i don't want to run into problems in the future.
thanks!
Old Sep 3, 2007 | 03:29 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: cat converter question.. (SIDEXIT)
If you can get a used one from a friend, that will be your cheapest solution. Other than that, there are plenty of companies that make direct fitment of catalytic converters for your application.
Old Sep 3, 2007 | 04:52 AM
h2392si's Avatar
Default Re: cat converter question.. (NVturbo)
All those OBD-2 high flow cats that wont give you any CEL's only last about 2 years anyways so keep that in mind. Yes, try to find a used one from a friend or junkyard. Good luck.
Old Sep 3, 2007 | 05:16 AM
SIDEXIT's Avatar
but will they pass inspection?
Old Sep 3, 2007 | 05:19 AM
97Ej6mike's Avatar
Yes, ive rarley heard of anyone failing emissions because of a high flow cat.
If you feel that insecure tho, you should look into finding another OEM replacement
Old Sep 3, 2007 | 06:07 AM
spooncivicsi's Avatar
Default Re: (97Ej6mike)
If i was in your situation (no smog here in hawaii) i'd run a REPUTABLE high flow cat like carsound on the street and keep another stock cat (say if you got one from a friend) on the side. And when smog comes around and if you feel like the high flow cat wouldn't pass, just slap on the stock cat. Its only 5 bolts and is relatively painless to change out.
Old Sep 3, 2007 | 06:51 AM
SIDEXIT's Avatar
lol i was thinking that. but i think the inspection in houston,tx is really strict. i'll probably go for a hi-flow replacement, but if i find a oem then cool.
thanks guys!
Old Sep 3, 2007 | 08:52 AM
vandersmissenc's Avatar
Default Re: (SIDEXIT)
inspection here isn't bad at all, i have a really crappy high flow cat and i passed. So get a good brand high flow cat and you should have no problems. Otherwise go with OEM that gave me better passing results in the past.
skaternak
19
Nov 24, 2009 04:07 PM
My JDM EJ8
Sep 16, 2008 04:43 PM
Cypher0117
May 2, 2006 04:58 PM
PearlWhiteAccord
Jan 16, 2004 08:31 AM
