Check Engine Light, Codes P0700 and P0730
Check engine light came on. '98 make and automatic. Ran a diagnostic and the codes P0700 and P0730 came up. As far as i know,
P0700 - Transmition control system malfunction
and P0730 - Gear Ratio incorrect.
Some help on how to solve this would be greatly appreciated.
Actually it does. It's hard to explain, but it's as if it isn't shifting correctly, and not only that it's been eating up a lot more gas. We've tried reseting it with some kind of OBD2 scanning tool. It actually worked for about a day, but then it started to act up again and the service engine light came back on just last night.
pp.com doesn't seem to work at all. Would it be possible to directly link me?
Other than that, if this is a trans. control system malfunction, wouldn't that mean there's something wrong electronically instead of mechanically wrong with the trans.? I wouldnt want to spend money if this can be solved electronically.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oversoulx2 »</TD></TR><TR><TD CLASS="quote">Check engine light came on. '98 make and automatic. Ran a diagnostic and the codes P0700 and P0730 came up. As far as i know,
Some help on how to solve this would be greatly appreciated.</TD></TR></TABLE>
p0730/p0740 codes are basically tranny killer codes. we get these codes all the time at Acura for TL's. whenever we get these codes, we just replace the transmission.
you might also have to replace the ecu/pcm and fuel pressure regulator. this is determined by VIN. don't ask me if you need to replace these cause I always let the parts guy worry about it. lol...
