ls vtec build.
i am looking as the golden eagle lsvtec kit and i noticed they have two head gasket sizes. they have 81.0mm and 84.0mm thickness. what is the difference in usage? i and going to turbo charge it at about 10psi max. and im looking for about 200 to 250 to the wheels.
I think the difference is the heads. Non vtec to vtec.. not all b series motors share the same part numbers.
hell even the waterpumps are different.
the ls headgasket seals better because it matches the block, the vtec one isn't wide enough in certain spots so there is a bigger chance it will blow through. all you really have to do is search, there is a lot of info on ls vtec's on here
