calling all b16a gurus
Old Jun 14, 2002 | 11:15 PM
mrduque's Avatar
Default calling all b16a gurus
i've been posting this all week and haven't had any godd suggestions. does ne one know if a disconnected ground would cause a b16a from starting? How man grounds are there, and where are they?.. My swap is done but won't start. Turns over but won't start (no fuel or spark). Fuel pump doesn't prime (no voltage goin to pump), no spark. Gonna check main relay, Not getting any errors, but check engine light stays on.. Light doesn't even recycle. Just stays on. Could low oil pressure cause this?
Old Jun 15, 2002 | 12:43 AM
Kamin's Avatar
Default Re: calling all b16a gurus (mrduque)
YES! bad engine/tranny grounds could cause this
there are 2
one on the transmission
one on the valve cover.
good luck
edit: make sure your battery neg. cable has a good clean connection too.
[Modified by KAMiN, 1:44 AM 6/15/2002]
Old Jun 15, 2002 | 10:05 AM
Jaker's Avatar
Default Re: calling all b16a gurus (KAMiN)
There is also a ground that is part of the engine wiring harness, and attaches to the engine at the thermostat housing. It is well hidden behind where the upper rad hose connects to the block, and easily missed. It attaches with a 10mm headed bolt, and has several key ground connections that are dependant upon its tight, clean attachment.
[Modified by Jaker, 11:07 AM 6/15/2002]
Old Jun 20, 2002 | 02:04 PM
iwhichisme's Avatar
have oyu checked your timing?
Old Jun 20, 2002 | 03:00 PM
Kamin's Avatar
Default Re: calling all b16a gurus (iwhichisme)
timing wouldnt cause no fuel.
Old Jun 20, 2002 | 05:05 PM
sleeper4dr's Avatar
check your main relay. it could be a bad ground because a bad ground can cause all sorts of problems, but it sounds more like your relay to me.
whats your setup btw?? that might help
Qxio
15
Dec 26, 2013 02:29 PM
Hellbert
Feb 9, 2005 01:17 PM
2k1_ITR_0736
Jan 27, 2003 06:01 PM
mrduque
Jun 13, 2002 12:22 AM
mrduque
Jun 12, 2002 09:44 PM
