90-93 gsr axles into del sol vtec
Old Sep 2, 2007 | 07:37 PM
b16a3delsol's Avatar
Default 90-93 gsr axles into del sol vtec
i finished my b16 del sol and used 90-93 gsr axles and halfshaft. the car runs fine but i just happen to have a bad axle on the drivers side. i have had conflicting opinions on if I could use the halfshaft and axles. obviously i can but I need to know just what all is needed for it to be right. I just heard something about a drivers side axle seal. help is greatly appreciated. sorry for the long post.
Old Sep 2, 2007 | 07:55 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: 90-93 gsr axles into del sol vtec (b16a3delsol)
If I'm not mistaken if the axles are from a cable tranny they won't be compatible with a hydro tranny.
Something with male/female ends not matching up.
Old Sep 2, 2007 | 10:54 PM
Kyoh's Avatar
Default Re: 90-93 gsr axles into del sol vtec (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">If I'm not mistaken if the axles are from a cable tranny they won't be compatible with a hydro tranny.
Something with male/female ends not matching up.</TD></TR></TABLE>
I think this only comes into play between halfshafts. You have to use axles for a hydro and halfshaft for a hydro and vis versa for cable. However, I'm still not sure about if they can be interchangeable between trannys but would really like to know.
Old Sep 3, 2007 | 12:21 AM
USDMCIVICHATCH's Avatar
Default Re: 90-93 gsr axles into del sol vtec (Kyoh)
it does work, and he said they are already installed and working so he knows that. As for his question about the driver side axle seal there isn't one, because the axle on that side goes to the intermediate shaft not into the transmission.
Old Sep 3, 2007 | 05:48 AM
Default Re: 90-93 gsr axles into del sol vtec (USDMCIVICHATCH)
thats what I thought but I read somewhere that it needed to be changed and im about to go to the track and dont want to break my dd.
mycivicislower
Mar 27, 2008 09:24 PM
GiT LaO'd
Jan 17, 2008 06:08 PM
prolifik22
Aug 22, 2007 07:15 PM
civic_crazy02
Jun 10, 2006 04:48 PM
