FS:94+ Integra suspension brakes swaybars , Aftermarket Gauges , 15" steelies
FS:all of the suspension stuff is off a 95 Integra LS,except the rear swaybar.this car was driven before being taken apart,so everything worked.this stuff has been in storage for a couple months,so i'm assuming it's all still in good shape as far as calipers,etc.
-front 10.3" brake conversion.complete spindle/rotor/hub/caliper assemblies.brake lines are cut.rotors slightly rusty,probably useable.
$125
-front LS 22mm swaybar.includes bar and D-bushings only.i have ONE of the front LCAs with swaybar mounts,the driver side.
$35 for the bar,$15 for the LCA
-rear disc conversion.complete trailing arm/toe link/hub/rotor/caliper/LCA/cable setup. brake hoses and cables are cut,but i do have an uncut set of E-brake cables to include.driver side LCA is missing the inner sleeve on the shock bushing.i can also remove the hub assemblies from the trailing arms to cut donw on shipping cost/size.rotors slightly rusty,probably useable.
$125
-rear GSR swaybar.complete,including bar/endlinks,D-bushings and brackets/mounting brackets/endlink to LCA bolts.all you need to bolt this onto a non-swaybar car is LCAs and four bolts to attach the mounting plates to the subframe.
$50
$275 for the whole suspension setup.
-2-1/16" Faze boost gauge.lights up,i used a vacuum pump to demonstrate vacuum and boost.
$20
-2-1/16" Autometer Phantom mechanical oil pressure gauge,0-150psi.lights up,i was able to verify 15psi with my crappy pump on it.red bulb "condom",can be removed to make light white.dirty,just needs to be cleaned up.
$25
-2-1/16" Autometer Sport Comp A/F gauge.
$25
-Hyundai OEM steelies.
15"x6"
4x114.3mm
+46mm offset
$50
all prices are plus shipping,from Roanoke,VA 24012.i can give shipping quotes,just give me your zip and what items you want.prices are negotiable.plenty of references if needed.
THANKS
Chris
Modified by TeamNextGenChris at 9:26 PM 9/8/2007
$125
$125
$50
$20
$25
$25
15"x6"
4x114.3mm
+46mm offset
$50
THANKS
Chris
prices lowered,reflected in the original post.
Thanks
Chris
Thanks
Chris
still got all this stuff for sale!make offers!
Thanks
Chris
Thanks
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roastbeefrichie »</TD></TR><TR><TD CLASS="quote">pm'd</TD></TR></TABLE>
replied.
still have rear swaybar and a front GSR bar.
chris
replied.
chris
naylor16
Jul 9, 2009 07:46 AM
*Boostwerks*
Nov 24, 2006 02:31 PM
